AE vs IDS clone
Old Jan 10, 2021 | 01:44 PM
  #316
Moony919's Avatar
Moony919
Has anybody ever reflshed ecm tcm and ficm with this clone successfully?
Old Jan 10, 2021 | 01:59 PM
  #317
Motohead911's Avatar
Motohead911
Yes I have
Old Jan 10, 2021 | 02:04 PM
  #318
Moony919's Avatar
Moony919
Originally Posted by Motohead911
Yes I have
I want to reflsh my 03 to the latest calibration but I don't want to have it brick my trucks software
Old Jan 10, 2021 | 04:59 PM
  #319
Yahiko's Avatar
Yahiko
Yes I have
Can you go into some detail about the process?
Thanks
And for people asking I am no longer doing any importing of this device.
Maybe when the import tax goes away I might.
Old Jan 10, 2021 | 05:52 PM
  #320
Motohead911
WARNING. I used the SVCI from flyobd the perform this operation.
It was nothing very hard. When hooked up to the truck, go into module programming and pick pcm. Then just follow the commands. When you do the pcm it starts with telling you to remove the ficm relay, then ids will flash the pcm, ficm and tcm.
That is how I remember it. It was about 2 years and v113 of ids.
Old Jan 10, 2021 | 08:01 PM
  #321
Moony919's Avatar
Moony919
I have the same clone purchased from flyobd everything works if you follow the install instructions on this thread. I was just nervous about the module programing cause its a clone, all the other features I've tried work good. But what I don't get is all the videos I've watched said u need to be connected to the internet to do module programing cause it gets the calibrations for the programing off of the ford servers. With this being a cline how does it work? Did u have to connect to the internet?
Old Jan 10, 2021 | 08:29 PM
  #322
Motohead911
Well I did connect, and it worked. Sorry just can't really tell you more, I did it once like 2.years, but it worked.
Old Jan 10, 2021 | 11:20 PM
  #323
Yahiko's Avatar
Yahiko
I think the trick is having the calibrations files and pointing the software at the location you have them stored.
Old Jan 11, 2021 | 12:52 AM
  #324
Hartwig's Avatar
Hartwig
Did somebody read engine hours with it? I only see the miles.
Old Jan 12, 2021 | 08:02 AM
  #325
CTroxtell's Avatar
CTroxtell
so on step 7 do I skip that cause its crossed out?
Yes, the strike-through on step 7 was a temporary to get it to work for the other forum members at the time. At the time I had posted this I was working with the guys at FlyOBD and I was the only one that had the correct files for making the app work until they pushed the new files out on the website, so I was just sharing them, once they pushed the updates I did the strike-through.
Old Jan 13, 2021 | 02:18 PM
  #326
Moony919's Avatar
Moony919
oh I did what was in step 7 i wonder if I should Uninstall everything and do it again and skip step 7. Software does work with the way I installed it just didn't know I was supposed to skip step 7 lol
Old Jan 28, 2021 | 02:17 PM
  #327
tocguy's Avatar
tocguy
Wow, reading this thread reminds me of how paying too little for a thing can result in the thing not doing what you had intended and/or it costing you more in the long run anyway. The number of hours some folks spent fussing/tinkering/troubleshooting was significant. Sharing that info here is priceless and cannot be overstated. That said, perhaps the operability work is now done and it's safe to purchase the FlyOBD unit. Is their SVCI J2534 ready? Does it perform the tasks that it advertises? Can it obtain Ford module updates and re-program them?
All the money in the world won't buy me another moment of time and every day I have less of it left to spend so I must balance both time and money resources.
The real acid-test question: Looking back with 20/20 hindsight; would you have given greater consideration to the Ford VCM/IDS product? I ask because I'm making that decision now.
Thx
Old Jan 28, 2021 | 06:59 PM
  #328
Yahiko's Avatar
Yahiko
I think I posted this link in the past but in case I did not here is the how to activate the special
functions in clone IDS/VCM2 units from china.
Old Jan 28, 2021 | 11:27 PM
  #329
tocguy's Avatar
tocguy
Noob question as I learn the lingo: Are these calibration files the ones from the Motorcraft Service - Module Build Data (As-Built) site? Enter a VIN and it pumps out a lengthy table of stuff that you need a secret decoder ring to understand. It also provides a link to download the file.
Site navigation: MotorcraftService.com -> Free Resources -> Quick Guides -> Module Build Data (As-Built)
The dump contains a top Note stating "When prompted, be sure to save or copy the file to the following IDS directory: c:\Program Files\Ford Motor Company\Calibration Files"
Old Feb 18, 2022 | 01:41 AM
  #330
High_HP's Avatar
High_HP
Need help
Deleted, got it figured out.
