AE vs IDS clone
Old Feb 5, 2020 | 03:23 AM
  #286
Yahiko's Avatar
Yahiko
If I have some time in the afternoon between swapping out rear axles I will try to get a look at that for you.
Old Feb 5, 2020 | 09:18 AM
  #287
hanoverclarkegs's Avatar
hanoverclarkegs
One more issue, I've got the STIC hardware running on Win10 with IDS v116. Power balance works and I can turnoff compensation and individual injectors. Turbo test doesn't seem to work, although it does set the RPM appropriately, but then doesn't run the turbo vanes up/down and says test complete and no test results.
Old Feb 5, 2020 | 04:24 PM
  #288
Yahiko's Avatar
Yahiko
If you have a deleted EGR valve it won't work.
Turbo test needs the EGR Valve, MAP and EBP sensors.
Old Feb 5, 2020 | 07:16 PM
  #289
hanoverclarkegs
EGR intact, but codes p0488 and p1334 present. I would assume these would prevent the test from running. Wonder why the SW wouldn't indicate that preconditions for the test aren't met.
Regarding IPR and EGR active commands, I wasn't patient enough and seems like several seconds for the command to execute.
Old Feb 5, 2020 | 08:48 PM
  #290
Yahiko's Avatar
Yahiko
Here is the test being run on a 2006 F350 IDS v86.
https://youtu.be/gjkoMivEVhk
https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/697578-p1334-p0448.html
For the IPR and the ability to command it.
The command is not being used in this buy you can see the IPR# along with the RPM#
The # tells you that is an item that Active Command can control.
Old Feb 6, 2020 | 08:43 AM
  #291
hanoverclarkegs
The ability to control #items with the active contol feature is very hit or miss, and mostly miss, with this STIC/IDS combination that I have. Once in a great while the #IPR, #EGRDC, #VGTDC will respond, never #FP to turn the fuel pump on/off.
Old Feb 16, 2020 | 09:42 AM
  #292
Rifleman7's Avatar
Rifleman7
IDS
Hello I was trying to PM someone about the IDS software And purchase it. If anyone could pm me and give me the details how I can get the clone I would apreaciate it.
Old Feb 16, 2020 | 10:27 AM
  #293
CTroxtell's Avatar
CTroxtell
Oh, that is nice to know now. Maybe that's why my turbo test does not work, not sure though since I think it still works, the ports are just closed.
Originally Posted by Rifleman7
Hello I was trying to PM someone about the IDS software And purchase it. If anyone could pm me and give me the details how I can get the clone I would appreciate it.
Just posted it on your visitor messages, your PM's are disabled.
Old Feb 16, 2020 | 11:07 AM
  #294
Motohead911's Avatar
Motohead911
I have the same issue with v116. When I ran v113 my turbo test worked.
I still have my EGR valve in place.
Old Feb 16, 2020 | 04:54 PM
  #295
Yahiko's Avatar
Yahiko
The turbo will work without the EGR valve. The test needs to see all the hardware to work.
Old Feb 21, 2020 | 07:04 PM
  #296
hanoverclarkegs
Ended up uninstalling IDS v116 and dropping back go v113. Turbo Test, and all active commands work as they should. When an active command for the fuel pump, for example, gets transmitted, the FP# changes to FP= in v113 and I assume this indicates the command is accepted. In v116 it would display FP! likely indicating the command is rejected. So, I assume this is likely a bug in v116.
Old Feb 22, 2020 | 03:09 AM
  #297
Yahiko's Avatar
Yahiko
Have you also tried v86?
Old Feb 23, 2020 | 12:25 PM
  #298
hanoverclarkegs
No, just v113, v116
Old Feb 27, 2020 | 08:41 PM
  #299
Riley046.0's Avatar
Riley046.0
Originally Posted by rickkk
Hey, Sean I,m interested in one of the clones, I have a 2004 6.0 What are the cost? Thanks, Rick G.
Hi Sean this is my first time posting on here so forgive me if I do something incorrectly but I also have a 2004 550 with a late 2003 year model 6.0 in it, and I was also wondering about the correct clone with the ids software that would work best for diagnosing my engine. If you could contact me please I would appreciate it because I’m not sure how or if I can contact you privately. Thanks
Old Feb 27, 2020 | 08:47 PM
  #300
Yahiko's Avatar
Yahiko
Does the F550 have an OBD2 port of the round one?
