Monte's 04 Build Thread
I plan to run 1/0 to the fuse block then the same 4 gauge to my sub amp and ill see if I have enought 8 gauge wire to make it to my speaker amp otherwire I'll buy some 4 gauge wire rather be safe tgan sorry lol. I got 4 150A fuses for my amps is that right for the speaker amp? My sub amp takes the 150A fuse. I orders 5 feet of 0/1 gauge so I will use the left over wire to beef up the cab to frame ground. I will do the Big 3 eventually.
I'll let you know about the lights, I saw them and for that price I figured I couldn't go wrong, worst case the F150 will get them lol.
Her birthday is 03/23/2004 (March 3, 2004)
Primary Features
Build Date: 23.03.2004
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Super Single Cab
Version: 250 Series
Engine: 5.4L Modular SOHC V8
Transmission: E4OD(4R100)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.73
Emission: With California/Green State Req
Air Conditioning: Manual Air Conditioning
Paint: Dark Shadow Gray
Minor Features
Medium Flint
With Cloth Trim
Jeremy seemed to hav a lot more info but this is all that came up lol.
Primary Features
Build Date: 29.07.2003
Version: 250 Series
Transmission: 6 Speed Manual
Axle Ratio: 4.10
Emission: With 49 State/Non Green State Req
Paint: Silver Met Waterborne
Minor Features
Medium Flint
With Cloth Trim
Links
Blocker Beam-Underbody Front End
With Tailgate Lock
With 6 3/4' Styleside Steel Box
With Load Box Edge Protectors
142"/3607MM Wheelbase
(-)"XL"
(-) Version Packages
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Less Security Lock Group
Less Special Equipment Package
Complete Vehicle
8800 LB. GVW
With Appearance Package
Less Exterior Appearance Pack
Less Power Equipment Group
Less Ambient Temp/Speed Pack
Job No.1 To Mid Year Program Ctl
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 2 Ton Mechanical Jack
With Manual Front Windows
With Hinged Side Windows
With Tinted Glass
With Fixed Rear Window
Less Overhead Console
Less Floor Mounted Console
Fixed Foot Pedals
Less Front Floor Mats
Less Rear Floor Mats
Floor Cover - Vinyl Ins - Complete
Sunvisor - Single Driver W/Strap
With Sunvisor Mirror - Passenger
With Level 1 Door Trim Panel
Grab Handle Side Door - Plastic
Less Exterior Sun Visor
With Grey Grille
Less Exterior Wheel Lip Moulding
Less Lower Body Moulding
With Side Auxiliary Step W/O Lights
With Dipping Rear View Mirror
Dual Sail Telesc TT Mirror-Manual
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With 2nd Row Bench Seat - 3 Passngr
With Driver 2 Way Mnl. Seat Adjust
With Pass 2 Way Manual Seat Adjust
Trailer Tow Prep Pack
With Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
With Manual Door Locking
Less Door Entry Remote Control Unit
Less Keyless Entry System
Less Sun Roof
Less Body Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
With Passenger Air Bag Deactivation
With Frame Mounted Tyre Carrier
With Steel Spare Wheel
Std Duty Dual Front Shock Absober
With Standard Rear Shock Absorbers
With Single Rear Wheels
7 X 16" Steel Road Wheel
LT265/75R-16E A-T BSW Tyre
LT265/75R16 BSW A/T Spare Tyre
With Full Wheel Cover
Less Wheel Nut Covers
Less Hub Covers
Less Immersion Heater
Less Stabilizer Package
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Stabilizer Bar
Less Rear Axle Package
4.10
Rear Axle Limited Slip Differential
Ford Axle Type
With Mono Beam Front Axle
With Catalyst
Less Exhaust Pipe Extension
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
Trans Power Take Off Provision
Man Transfer Case And Man Hubs
Less Skid Plates
Less Clean Fuel Fleet Vehicle
With Mid-Ship Fuel Tank
For Unleaded Fuel
Less Steering Damper
With Tilt Steering Wheel
Basic Type Steering Wheel
With Speed Control
With MPH/KMH Speedometer
Instrumentation Pack
Less Reverse Proximity Sensor
Heavy Duty Battery
Heavy Duty Alternator
Elect AM/FM/Stereo/Cassette/Clock
With NAAO Radio Frequency
Less 4X4 Version Pack
High Front Lamps W/Signature DTRL
Less Daytime Running Lamps
Less Front Fog Lamps
Less Roof Marker/Clearance Light
Less Engine Compartment Light
With Dual Beam Dome Map Light
Less Glove Box Illumination
Tail lamps - Level 1
With High Mounted Stop Lamp
With Conventional Headlamp Control
Left Front F81A-5310-ADD (4400 LB.)
Right Front F81A-5310-ADD (4400 LB)
Less B&A Control Codes Issue 030388
Less B & A Control Codes (9270)
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"BO"
Mrkt Comb-SD Airbag Drvr/Pass
In the minor feature section, there is a link after cloth trim. Its very small, but it says "There are more minor features for this vehicle, click to expand this list."
Minor Features
Medium Flint
With Cloth Trim
Brick Cloth
With Tailgate Lock
With Base Payload Package
XLT
U.S. Sales
With Snowplow Pack
Complete Vehicle
8800 LB. GVW
Less Appearance Group
With Power Equipment Group
Mid Year Change Program Control
With Power Front Windows
With Privacy Glass
With Sliding Rear Window
Fixed Foot Pedals
Front Floor Carpet Mats
With Carpet Floor Covering
With Level 3 Door Trim Panel
With Bright Front Grille
Chrome Tube Side Steps W/O Lights
Telecsp TT Pwr Htd Lighted
With Black Exterior Mirror
Trailer Tow - Class III Receiver
With Central Locking System
Less Sun Roof
With Fr Seat Integrated Restraints
With Driver Air Bag
7.0 X 16" Chrome Clad Steel Wheel
LT265/75R-16E OWL A-T Tyre
Less Wheel Covers
With Bright Wheel Hub Cover
3.73
Ford Axle Type
With Catalyst
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
With Skid Plates
For Unleaded Fuel
With Steering Damper
With Speed Control
Heavy Duty Battery
With AM/FM CD Player
Roof Marker/Clearance Lights-Conv
With Glove Box Illumination
Dark Shadow Grey
Dark Shadow Gray
F81A-5310-AHD (6000 LB.)
F81A-5310-AHD (6000 LB.) #2
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"AW"
Some BS in here because i don't have a glove box light lol
My 04:
My 02:
F81A-5310-AFD (5200 LB.)
F81A-5310-AFD (5200 LB.) #2
Yours:
On the 04s, we both had standard duty front and rear suspensions. My 02 has the Camper Pack. Your 04 has the plow pack.
Also here is a pic of my progress i have made on my 08 dash swap
I know this is not a build thread for my 95 but i put the old tires from my 04 on it today. I might start a 95 build thread, it will be slow but i will be able to track progress.
Since I've tinted my windows the mirrors are not very useful in pitch black. And the back up camera is useless if it's raining or snowing so more light down range would help a bunch in being able to back up.
How did you fit 32s on a stock f150?
Honestly winged it they looked like they would fit and they were the same width as the tires that were on it just taller. Once i get her running i think i may find that it hits the bumper valance.
Here is it against the side of the house about 15 feet away.
Here is the fence 100 feet away from the truck.
Before:
After:
The pool about 80 feet away
Before:
After:
Also here is the dog 4 feet away he was chasing the light and it amused me lol:
Those reverse lights look good too. I've been wanting to get some for mine as well, but not sure what. Would like to see them lit up as well.
The 95 looks great with the different tires and wheels. Its amazing how much just tires and wheels will completely change the look of a truck. Looks way better to me.
Hey Matt how's the Smittybilt receiver D-ring shackle holding up? Got any more pictures of it? I was thinking about getting one for my truck, and was wondering how it would look.
Edit: Never mind. Wow those things are bright! And look good too. Man, I think I'm going to have to get those for mine. Looks like they would make a great reverse light. Thanks for the pics.
For the dash I just bought the cheapest parts because I will be painting black and charcoal. I will probably paint it soon, check out my swap thread linked in my sig.
I have not been driving the truck much so the receiver has not been getting beat up but honestly it is good quality. I can see how the finish might not be great and may chip off after a while but I would definitely buy another one in a heartbeat.
