Sponsored by: Real Truck
Monte's 04 Build Thread
Old Jan 30, 2014 | 07:06 PM
  #106
xmontex4's Avatar
xmontex4
Originally Posted by Dwood63
Your tail lights, and inner door panel nice! Where's ya get the tail lights? And was the door panel a pull and play?
Thanks! They are recon "Dark Red" tail lights. The door panels require some modifications to fit but nothing major. They will contact the 99-07 dash but not enough to really matter. Basically you need to remove or cut the black inner handle bucket and then hook on the door panel like normal. Also you will need to repin the driver side window switch and then get a new connector for the mirror switch. I have a work around for the door locks posted earlier in the thread, I highly recommend going that route rather than trying to get the new connector to work with the old wiring.
Edit: Also you need a new wing panel (the black plastic piece that covers the mirror bolts)
Old Jan 30, 2014 | 07:15 PM
  #107
kwztoy's Avatar
kwztoy
Are those pioneer subs shallow? i got an 03 f250 same as yours, 4 door extended cab, and when I did my system I couldnt fit an regular 12 inch sub under the back seat, so I got an 12 inch kicker shallow sub that already comes in a box, its only one but I am planning on getting another one
Old Jan 30, 2014 | 07:19 PM
  #108
Dwood63's Avatar
Dwood63
Originally Posted by xmontex4
Thanks! They are recon "Dark Red" tail lights. The door panels require some modifications to fit but nothing major. They will contact the 99-07 dash but not enough to really matter. Basically you need to remove or cut the black inner handle bucket and then hook on the door panel like normal. Also you will need to repin the driver side window switch and then get a new connector for the mirror switch. I have a work around for the door locks posted earlier in the thread, I highly recommend going that route rather than trying to get the new connector to work with the old wiring. Edit: Also you need a new wing panel (the black plastic piece that covers the mirror bolts)
Okay thanks a lot buddy! Great looking truck btw
Old Jan 30, 2014 | 07:25 PM
  #109
xmontex4's Avatar
xmontex4
No problem man, thanks again!
Old Feb 15, 2014 | 03:24 PM
  #110
xmontex4's Avatar
xmontex4
Got a bunch of stuff in today:
-4x foam 6x8 speaker baffles
-2x blue sea fuse panels
-blue sea usb charging socked
-2x hella 4 relay panel
-some latex tubing for my door seals
-license plate cover to fill the hole in my 08 dash
-some other misc. stuff
Also My parents gave me an early birthday present! They got me an Edge Insight CTS, i had planned to use it when i eventually do a cummins swap to monitor the gauges that i dont have already in my cluster that are normally there on diesels.
Also i took this the other day, does it look like its leaning to the pass side or is it just me? How do i fix it?
Waiting for the photo to upload the photobucket app isn't agreeing right now...
Old Feb 15, 2014 | 03:28 PM
  #111
xmontex4's Avatar
xmontex4
Hey KW i'm so sorry i didnt see this until now, they are 10" pioneer shallow mount subs, They currently stick out 2" with my box but i made it too short and fat so it can be made taller and skinnier so it doesnt stick out. I will be rebuilding it this spring so keep watch! I highly recommend them they make some good bass for shallow mounts and for the amount of space there is honestly couldn't be any happier with them!
Old Feb 15, 2014 | 03:33 PM
  #112
02TB250's Avatar
02TB250
Looking good Matt. Looks like you've got everything in order. How's the dash progressing?
Sent from my Galaxy using IB AutoGroup
Old Feb 15, 2014 | 03:39 PM
  #113
xmontex4's Avatar
xmontex4
Thanks Justin, good this was the next phase of stuff i ordered, doing a lot of rewiring once the dash comes off. I have a couple switches form OTTRAW on the way should have them this week or next. I'll be ordering the paint this week then start painting the dash pieces once we have a warm enough day to do it.
Old Feb 15, 2014 | 03:58 PM
  #114
xmontex4's Avatar
xmontex4
Finally got the picture to upload, does it look like its leaning to the passenger side? How do you fix the lean new springs?
Old Feb 15, 2014 | 04:39 PM
  #115
Dwood63's Avatar
Dwood63
It looks fine to me honestly
Old Feb 15, 2014 | 05:25 PM
  #116
xmontex4's Avatar
xmontex4
Ok maybe its just me then, the past few days I tgough it looked like it was leaning.
Old Feb 15, 2014 | 06:03 PM
  #117
02TB250's Avatar
02TB250
Clean out your bed, it could be the snow, but take a tape measure and measure to the wheel wells, that will give you an accurate measurements. I usually have to do it once a month. Residual paranoia from my explorer(gangster lean). It's probably not actually leaning.
Old Feb 15, 2014 | 06:17 PM
  #118
xmontex4's Avatar
xmontex4
I hate the lean as well, I actually have a tonneau cover so the beds empty right now. Its wierd too bc the gas tank is on the driver side and I sit on that side
Old Feb 16, 2014 | 02:37 PM
  #119
xmontex4's Avatar
xmontex4
I still havn't measured each wheel yet, I'm waiting for the snow to melt so i can go right to the ground and make sure its accurate.
I installed my speaker baffles and some latex tubing in my door seal today.
The main reason i did the speaker baffles was to prevent corrosion on the speakers because my stock ones were very rusty and nasty looking before i replaced them. I didn't trim the rear ones but in the front i trimmed around the speakers in order to not interfere with the door panels.
I will post up a picture of the CTS installed later tonight.
Old Feb 16, 2014 | 02:44 PM
  #120
MC45's Avatar
MC45
Wow! That looked like an opportune time to get wires from the door panel to fuse box area while all is open.
