Thanks! As soon as I seen that two tone on an obs, I knew that's what I wanted on mine. Kicking it old school is what everyone told me when I told then two tone, and now everyone compliments it.
I haven't tried it yet, but if you coat your floor with lin seed oil, will keep stuff from soaking in to the floor, I figured it was new, stuff hasn't started collecting along the walls
nice paint job, why did you pull the emblems off the front.
There is a plastic based coating, but diesel fuel destroys it, the stuff works very well where I havent spilled fuel. The side emblems and front emblems I thought were ridiculously priced from LMC. So I picked up some endless highway ones for the side and still need to get billet badges made for the front and doors.
Your lucky you got that nice shop.....We set a record for the wettest September, Rained 22 out of 30 days....I felt like one of the soggy bottom boys here lately....
That's no doubt...
It literally rained the hardest ive ever seen the other day... and Im a WA native.... I swear the Raindrops were 1" in diameter....
Crazy... im burned out on it....
Justin, what should I do about the pump, which way does it need to go and/or show should I slide the pump if it's only one tooth off?
The Pump needs to be 1 tooth ahead of the cam.
To put it simply, if you were to line everything up dot to dot, and then you pulled the cam out and rotated clockwise one tooth, that's where you would want it. So the pump needs to be one tooth ahead of the cam, or in otherwords, one tooth to the left of the cam.
I think his pics are correct....The other member put up a photo shopped pic of one 2 teeth off.... ARPS 6.9 pic is correct.... just get that bad boy running....
If he put it together as the pics posted in post 200 then the IP is retarded 2 teeth.
that to me looks wrong...if everything was lined up dot to dot than the cam was pulled and rotated right one tooth the ip marking would be on the left side of the cam marking
This is correct....
didn't mean for it to be this confusing..... Ill get a pic here soon, and make sure it exits with every cam...
