Just another "impossible" build
Old Sep 30, 2013 | 01:02 AM
  #211
BruteFord's Avatar
BruteFord
Originally Posted by racer30
He needs the cam retarded 1 tooth and the IP timed correct to the crank. This is how racin's stage one cam is run.
That would end up looking like this;
With an extra tooth(6.8 degree) of advance on the IP like this:
Someone else with more IP timing experience then me can chime on the idea of advancing the IP a tooth. But from all that I've read and on mine they generally end up advanced from the marks by quite a bit, seems to me a tooth over would be a good way to bring it back to the mark.
Old Sep 30, 2013 | 11:30 AM
  #212
Arps 6.9's Avatar
Arps 6.9
Well racer is it right? I hope so because my motor now looks like this
Old Sep 30, 2013 | 01:44 PM
  #213
Red454sedgwick's Avatar
Red454sedgwick
even if it's off a tooth you should have enough adjustment to make up for it. I advance mine a tooth, then I got a timing meter, I can go from 14 to 5 btc with the gear still advance a tooth
Old Sep 30, 2013 | 03:52 PM
  #214
Bonanza35's Avatar
Bonanza35
So wheres the turbo? looks great.
Old Sep 30, 2013 | 06:50 PM
  #215
Arps 6.9's Avatar
Arps 6.9
Another thing I think some failed to think about is that the cam gear is spinning backwards from the crank and ip, also from a gasser chain driven unit.
The turbo. Well I don't have it as I am being rushed go get it together by Sunday,so the turbo is not going on because I don't have enough time to order it, mount it and plumb it. Hopefully it's not to difficult to fabricate while it is in the engine bay
Old Sep 30, 2013 | 09:51 PM
  #216
typefour's Avatar
typefour
I want to know how that cam work NA, If it works well I may get one for the dually as it will be turning more rpm than the daily driver.
So please keep us posted.
Old Sep 30, 2013 | 10:43 PM
  #217
Arps 6.9's Avatar
Arps 6.9
Will do, it will be affected by the pistons being shaved .040 also, but take it as you will, I'll keep everyone posted.
Old Oct 1, 2013 | 11:32 PM
  #218
racer30's Avatar
racer30
My pistons are .030 and mine started and ran good NA with a even more aggressive Cam so you should be fine. I hope you get it done on time....I seem to keep getting side tracked on mine.... And Kid, Quit calling it a Motor. Its a Engine, its only started with a motor...LOL....
Old Oct 1, 2013 | 11:38 PM
  #219
Arps 6.9's Avatar
Arps 6.9
I know so do I, should have it in the truck tomorrow night, bed on, temp. fuel tank in and left with minor plumbing for Thursday after I get paid. And yeah my bad, it's usually just whatever is in my head. But I do know the difference! Haha
Old Oct 3, 2013 | 12:00 AM
  #220
Arps 6.9's Avatar
Arps 6.9
that's my progress! If I can get a return line kit tomorrow it will run tomorrow. Trans and following driveline parts to install, and run some fuel line!
Old Oct 3, 2013 | 12:09 AM
  #221
RacinNdrummin's Avatar
RacinNdrummin
**** Austin, sorry for the lack of communication...
Your IP looks like its a tooth too far...
Ive had the cam in a N/A box van, and it runs great N/A, even better than I thought it would...
Old Oct 3, 2013 | 12:10 AM
  #222
Arps 6.9's Avatar
Arps 6.9
It is one tooth past the y, I can move it without too much trouble. If I can use the mirror trick.
Old Oct 3, 2013 | 12:30 AM
  #223
Red454sedgwick
I have to ask how do you keep a farm shop floor that clean?
Old Oct 3, 2013 | 12:31 AM
  #224
hairyboxnoogle's Avatar
hairyboxnoogle
Sharp truck man
Old Oct 3, 2013 | 12:33 AM
  #225
Arps 6.9's Avatar
Arps 6.9
It's brand new haha and that would never pass my dads standards for clean. I'll spend hours cleaning up my mess tomorrow! For real, scrubbing on my knees the oil stains out. It's a pain some times
