Just another "impossible" build
Old Apr 10, 2013 | 11:18 AM
  #76
parkland's Avatar
parkland
The little air cooled diesel in my go kart project has a lever on top, and I believe it holds the exhaust valve open for 1 revolution, so that the starter can get some momentum to turn it over through a compression stroke.
As for the starting issue, maybe an air intake grid heater off a cummins?
Old Apr 10, 2013 | 12:41 PM
  #77
Red454sedgwick's Avatar
Red454sedgwick
Originally Posted by Arps 6.9
Have you ever considered other problems? Mine has those same symptoms, at stock compression with 229000
yep I've played with the timing, it had new injectors when it was rebuilt, Put a new ip on it thought that might help. new glow plugs. It only uses oil when pulling hard and it has very little blow-by.
If you plug it in all night it still won't start with out glow plugs or starting fuild.
Old Apr 10, 2013 | 02:01 PM
  #78
hairyboxnoogle's Avatar
hairyboxnoogle
that goes for every IDI 22:1 or 18:1
Old Apr 10, 2013 | 07:58 PM
  #79
Red454sedgwick
thats not the case with my other one
Old Apr 10, 2013 | 10:25 PM
  #80
Arps 6.9's Avatar
Arps 6.9
That's where we are different, I have more blow by and burn oil, all the time, but new ip injectors and glow plugs still don't do much for me, so we are close to the same boat, I don't think its shaved pistons, I think mine burns oil through bad valve seals, and the starting issue I believe is fuel related.
Old Apr 10, 2013 | 10:41 PM
  #81
hairyboxnoogle
huh, mine wont start without help if its 100* out lol. My dads will eventually if its 80 or so, but you have to crank a WHILE
But my point is i guess, i know two guys with 18:1 or less and both starts just fine with GPs
Old Apr 10, 2013 | 11:18 PM
  #82
racer30's Avatar
racer30
Hey RED you got a electric fuel pump on your Truck?... You might have a small fuel/air leak that's making it start hard...
Old Apr 10, 2013 | 11:58 PM
  #83
Ford F834's Avatar
Ford F834
Thanks, Racin', for taking the time to type up that explanation. Very good cam info., and very much appreciated.
Originally Posted by RacinNdrummin
Mike, Actually, the big thing to bleeding off compression is the intake valve being open longer. Overlap has very little to do with "bleeding" compression, because 9 times out of 10 (thats conservative) exhaust pressure is going to be more than intake pressure, and that works the opposite way of bleeding compression off... A cam with very little overlap and an intake event with decent duration and a late ICL is going to bleed compression off. Ill compare the Stock cam, The R&D, and The J2 below (Id toss the typ4 in there as well, but russ hasent given me the specs yet):
The stock cam has 37* of total overlap (-27*@.050"), and the intake valve stays open for 42* after bottom dead center. It effectively stays open for 7* after BDC at .050", which is a good lift for dynamic measurement.
The R&D cam is 56* of total overlap (-24*@.050"), and the intake valve stays open for 52* after bottom dead center. It effectively stays open for 21* after BDC at .050"...
The J2 cam is 56* of total overlap (-12*@.050"), and the intake valve stays open for 74* after bottom dead center. It effectively stays open for 32* after BDC at .050"...
Putting these together... The further the intake stays open after BDC, the more compression is bled off. Reversion happens when there is too much overlap at too little flow (read:RPM or boost)... The stock cam doesnt have much total overlap, but has as much dynamic overlap as the R&D (which is negative anyway, meaning both valves overlap for less than 0* of duration when the valves are open to .050" of lift...)... The J2 cam has about as much total overlap as the R&D, but has more dynamic overlap at .050", meaning more chance for reversion at lower RPM's, but when higher RPM's and boost are achieved, there is more cylinder filling, and therefore more power.... This just covers the intake side though, there is more as far as the exhaust sides are concerned...
As far as the TYP4 cam is concerned, the best I can do with the knowledge I have of it, is that it increases lower end cylinder filling by increasing duration on the intake side, but maintaining stockish lifts and timing events as much as possible... This is why it works great in low boost and N/A situations, there is no exhaust pressure inhibiting cylinder filling, and the extra filling it gets from the intake event makes a little more torque lower in the RPM range.
Basically it coems down to where you want your cam to perform... The stocker is a good all around cam for everyhing, the TYP4 is better than the stocker at low RPM, the R&D is great for engines that spend their time boosting 10-20psi while doing work, and the J2 is great for WOT/Higher RPM/higher boost situations while doing work... They all have their place...
Old Apr 11, 2013 | 01:11 AM
  #84
Red454sedgwick
yep I have a carter rotery pump on it It will start on easily when it is 40+ if the gps are working. so I don't have an air problem, I used the truck mostly in the winter time so you can see why I don't like it.
If it is 20 or below even with good glow pulgs it is hard to start un less it has been pluged in for a few hours.
My other truck will start around 0 with out being pluged in, but it takes some cranking and you have to cycle the gps twice.
I'm going to to replace the pistons when I get the chance not matter what.
Old Apr 11, 2013 | 09:29 AM
  #85
hairyboxnoogle
If theyre decent pistons, i may be interested in them.
Old Apr 11, 2013 | 10:21 AM
  #86
Red454sedgwick
There just stock 30 over that the machnie shop guy took 050. off the top, he didn't touch the valve releave, right now they only have 7 or 8 thouand miles on them. I don't know when I will get it done it a cash flow problem. I want to rebuild my other one first. So it might be this time next year.
IF I remember that you want them all you would have to do is pay for the shipping and there yours
Old Apr 11, 2013 | 10:26 AM
  #87
Arps 6.9's Avatar
Arps 6.9
Those pistons shaved that much puts you at 16:1 or lower, probably part of the problem. If you need 7.3 pistons I have a set.
Old Apr 11, 2013 | 10:47 AM
  #88
Red454sedgwick
How did you come up with that? I was told when I did this that .010 was one compression point. I was going for 17:1 The block was decked .009
when I try this again I'm going for 20 to 1 I was told that hyper-max sells a set, but I havent called them yet.
Old Apr 11, 2013 | 03:32 PM
  #89
Arps 6.9's Avatar
Arps 6.9
I was told around 1.2, with the block being decked that would make it closer I guess, but the recess in the pistons skews things.
Old Apr 11, 2013 | 03:51 PM
  #90
hairyboxnoogle
Stock .030" over? Please clarify.. what brand are they?
Short of doing math im going to say youre nowhere near 16:1, more like 19:1
