Just another "impossible" build
Old Sep 15, 2013 | 07:05 AM
  #181
2020's Avatar
2020
If you are talking about the head alignment dowels (pins), they are the same as a 4.6 eng. We had to get new ones at the local Ford dealer when we built my sons' 6.9.
Old Sep 15, 2013 | 10:55 AM
  #182
Arps 6.9's Avatar
Arps 6.9
Originally Posted by NMB2
that is right.
Ok, I just questioned it because the old gaskets did not block off those ports, Thanks!
Old Sep 15, 2013 | 10:57 AM
  #183
Arps 6.9's Avatar
Arps 6.9
Yes that is what I was talking about, but since I have studs I can see where they would help align the gaskets. I will have to call Ford Monday, thanks cause I did not know where I was going to find those!
Old Sep 19, 2013 | 06:50 PM
  #184
Arps 6.9's Avatar
Arps 6.9
Got the heads on and torqued to 95ft-lbs. One question I have is dealing with the cork gasket that felpro includes with it's conversion kit. It did not come factory with the cork oil pan gasket, so has anyone used it?
Old Sep 19, 2013 | 06:59 PM
  #185
hairyboxnoogle's Avatar
hairyboxnoogle
I have one on mine. Doesnt leak if you keep the bolts tight, but they are always working loose, about every 6 months they are only finger tight... same goes for the valve covers.
Old Sep 19, 2013 | 07:44 PM
  #186
Arps 6.9's Avatar
Arps 6.9
What about lock-tightening them? Just to keep them tight? And did you use rtv or anything else when you installed them?
Old Sep 19, 2013 | 09:31 PM
  #187
hairyboxnoogle
I did put some silicone on them, apparently that didnt work. So maybe some green or blue locktite in the future.
Old Sep 19, 2013 | 10:02 PM
  #188
Arps 6.9's Avatar
Arps 6.9
I meant did you put any on the gasket itself? Or just use the cork gasket with no rtv?
Old Sep 19, 2013 | 10:21 PM
  #189
racer30's Avatar
racer30
The factory used only silicone RTV, So that's how I did it. Make sure to clean it good and test fit the pan so you can see where it lands on the engine...Draw with a sharpie around the pan then remove it and seal the hell out of it, let it set 10 min or so then install the pan and torque to spec.
Old Sep 19, 2013 | 10:39 PM
  #190
Arps 6.9's Avatar
Arps 6.9
I think I am going to do both, layer on both sides of the gasket, there is no way it can leak then, I have a hard time telling how much is too much of the silicone, and with everything so far I have done that to make sure everything seals as best as it can, I know the silicone can't hurt so why not? I can't have a seeping diesel on the new shop floor!
Old Sep 19, 2013 | 10:57 PM
  #191
hairyboxnoogle
I did gasket and silicone. In the future im pretty sure it will just be silicone.
Old Sep 20, 2013 | 01:28 AM
  #192
RacinNdrummin's Avatar
RacinNdrummin
95 should do it, but Id go at least to 100.... if you can get 110 out of them with ARP lube, do it....
Old Sep 20, 2013 | 06:04 AM
  #193
Arps 6.9's Avatar
Arps 6.9
I thought maybe they could be tighter but nmb2 is the one I asked about it. I'll bump it up some more. What's the status on those parts btw?
Old Sep 21, 2013 | 12:17 AM
  #194
BruteFord's Avatar
BruteFord
Still looking for a wiring harness? I got one from an 88, PM me if you are interested.
Old Sep 23, 2013 | 01:09 AM
  #195
RacinNdrummin
Did you get the parts Austin?
