Engine removal pics
Old Oct 7, 2012 | 10:34 PM
  #46
Yahiko's Avatar
Yahiko
Very cool that she helps
Sean
Old Oct 7, 2012 | 10:35 PM
  #47
run6.0run's Avatar
run6.0run
I've only got a sideways air rachet. My compressor ain't big enough to run my big impact. Flywheel holder??? Is that a real tool? Next to the blinker fluid. Lol.
Old Oct 7, 2012 | 10:40 PM
  #48
run6.0run's Avatar
run6.0run
See those rings. Is that normal? It feels smooth.
Old Oct 7, 2012 | 10:42 PM
  #49
run6.0run's Avatar
run6.0run
I mean those rings on the cam lobes. They're blue.
Old Oct 8, 2012 | 12:12 AM
  #50
run6.0run's Avatar
run6.0run
I guess I'm gonna go get a dewalt corded impact tomorrow. I've wanted one for years. Just never got one. I tried heat. Maybe I can find a flywheel holding tool..... Just did a search on it. Check it out
Wonder if this will work
Here's a couple pics of the tranny jack in action
Old Oct 8, 2012 | 12:48 AM
  #51
run6.0run's Avatar
run6.0run
I have a heavy duty hoist, I'm thinking about trying to pull the trans out from the engine bay. I would have to stretch out the crane tho. It's a 2 ton compacted hoist. It would prob have to be extended to the 1 ton length to work. Has anyone out here tried this??? I prob should have pulled them together, but didn't know if the crane would handle it. I might try and reinstall the engine and trans together tho. But I only have one hoist. And I can't mount the engine on a stand until I get those freakin flywheel bolts off. Not too crazy about setting the engine on the ground. Am I all screwed up in my thoughts??? Am I missing something that's obvious to you all. I'm open to any and all suggestions about anything.
Old Oct 8, 2012 | 01:18 AM
  #52
daddykitty's Avatar
daddykitty
Originally Posted by run6.0run
Btw, I've got a personal ? How many of your wives would be out here. For the whole thing. She's a trooper. Even if she does spend most of her time on her iphone. It's awesome to have her hand me stuff when I'm under or on my other love. Lol. We both drive tho. So it's her job also.
My wife would be out there turning wrenches and telling me how to do things according to some form of "written instructions". Does she not realize that instructions are not in the male vocabulary?
Old Oct 8, 2012 | 01:49 AM
  #53
Yahiko's Avatar
Yahiko
one flywheel tool This is to give you an idea on how to make one
BERGEN Professional Diesel Engine Flywheel Locking Tool Kit for Ford BER3162 | eBay
These are $$ and may take too much time to get
Flywheel Holding Tool Rotunda 303-103
Ford Motorcraft 303-103 Flywheel Holding Tool
You may need to set the engine on the floor so you don't flip it oven
but leave the hoist attached and maybe some 4X4 under the mounts.
When your ready to place it so you can free up the hoist I would use a
pallet and the 4X4 blocks to help keep t in place.
Sean
Old Oct 8, 2012 | 01:53 AM
  #54
Yahiko's Avatar
Yahiko
Just found a big page full of different types of holders.
flywheel holding tool - BuyCheapr.com
This may give you an idea home to make one.
Sean
Old Oct 8, 2012 | 02:25 AM
  #55
run6.0run's Avatar
run6.0run
I thought u were bs' ing me about the holding tool. Lol. I'm gonna try the wrench wedged in two bolts. I posted a pic of it. Man I hope this works. Actually, I guess if it doesn't, then I can just leave it with the core.
I'm considering keeping the core and having it rebuilt. Gonna wait to get the heads off to decide. I could take them off to see if I can tell what went wrong.
I've been reading about stuck flywheel bolts and a lot are saying I could grind the end off of the socket. All mine have the bevel before the actual working part of the socket. Any thoughts on the electric impact? A lot of people were saying electric doesn't have the torque that air does. Dunno, just thinking that maybe someone else will be in this situation someday, so I'm throwing out all ideas.
Old Oct 8, 2012 | 03:35 AM
  #56
MisterCMK's Avatar
MisterCMK
Even a small compressor should be enough to at least bust loose the bolts with a good impact.
Old Oct 8, 2012 | 03:52 AM
  #57
Yahiko's Avatar
Yahiko
Because they blots are going to be replaced you
can heat them to break any thread lock compound.
Get them good and hot then let them cool. That is one
was and about the only way to free up any thing
that has been treated with lock-tight. That should help.
Sean
Old Oct 8, 2012 | 09:14 AM
  #58
run6.0run's Avatar
run6.0run
Hey cmk, I saw it suggestion about the misho ( something). Cac. Do you have one of them? I still haven't found out about mine from the radiator shop. It sux how expensive they are. Btw, what kind , or brand impact should I get? The rachet I have is fairly strong, but the big impact has no mojo.
Old Oct 8, 2012 | 09:25 AM
  #59
MisterCMK's Avatar
MisterCMK
I have a mishimoto radiator for my car. I hope their cac is better than the radiator. More on that later. For an impact wrench I like my IR2135
Old Oct 8, 2012 | 09:51 AM
  #60
run6.0run's Avatar
run6.0run
Is that ingersol rand? I have a Home Depot 16 gal comp. I think it's only like 2cfpm. How does that compare to yours. I sure wish I had room for a bigger comp
