I don't have a picture but I went out for a short drive today. I got my passenger side door back on and wanted to move my truck from the end bay to the other bay to get to the driver's side door.
So as I pulled the truck out, I figured I would drive around the block. That turned into a 5-6 mile drive. I would have gone further but my garage doors were open. Man it was nice going out for a drive. It was 60 degrees here today.
I had my 54 out today also. It was sunny here but only about 45°. I had to go to the pharmacy, the UPS dropoff and recycle cardboard, so I thought I'd take my truck. No pictures.
How'd your passenger door sound? Quieter? Less air coming in? Fewer rattles?
It is much quieter. It shuts nicer and is solid when closed. The window is a bit hard to crank up. I will need to check that closer. I also glued window to the bottom bracket so it would stay in the track. Hopefully that works.
I have the drivers side door off now and will get that one all fixed up as well. I removed the window and the bottom track was not attached to the regulator all the way and the window was loose in the bottom track.
I have a can of patio door spray lube. I'll post a picture of the can tomorrow when I get out to the garage. It helps the window slide up and down easier.
