Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Mar 2, 2020 | 02:49 PM
  #271
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 4x4slik
Can you decode this for me please?
F61 = F600 2WD (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
U81032 = 1975.
188" Wheelbase.
T = Candyapple Red.
F610 = F600 2WD (gas), 19,700 lbs. GVWR
E 8: E = Medium Red & Dark Red Vinyl - Full Width Seat / 8 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F3K:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
K = Ford 5,500 lbs. Capacity Front Axle with Power Steering.
19,700 lbs. Gross Vehicle Weight Rating.
561792:
56 = Davenport IA Ford District Sales Office, where the original selling dealer ordered the truck from.
1792 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Mar 2, 2020 | 05:23 PM
  #272
4x4slik's Avatar
4x4slik
Thank you kind sir.
Old Mar 5, 2020 | 12:03 PM
  #273
Dusty95's Avatar
Dusty95
Any help on this Louisville vin?
Can someone help me decode this vin picture? Its for an l8000 I'm
looking at buying.
Any and all help appreciated!
Old Mar 7, 2020 | 06:18 PM
  #274
NumberDummy
Originally Posted by Dusty95
Can someone help me decode this Certification Label?
Decoded in your other post.
Old Mar 31, 2020 | 01:33 AM
  #275
qat383's Avatar
qat383
Hello all
I have 66 f350. I would like to have the vin number information fF358E778738
Old Mar 31, 2020 | 06:09 AM
  #276
NumberDummy
Originally Posted by qat383
Hello all
I have 66 F350. I would like to have the VIN information F358E778738
The 4th digit is incorrect, should be a letter for the engine code.
Please ask further questions in the 1961/66 F100 and larger truck forum, this forum is for 500 and larger series BIG trucks.
F35 = F350.
The 8 is probably: B = 300 1V I-6.
E = Mahwah NJ Assembly Plant.
778738 = 1966.
VIN doesn't tell you much once it's decoded.
Post a pic of the Warranty Plate, riveted to the left door face below the latch, or type the info.
Old Apr 10, 2020 | 07:41 AM
  #277
Reydzzz's Avatar
Reydzzz
C-700 VIN
I was looking for some help with decoding this warranty plate. The trans is an M if it is hard to see. Thank you in advance!
Old Apr 10, 2020 | 12:38 PM
  #278
NumberDummy
Originally Posted by Reydzzz
I was looking for some help with decoding this warranty plate. The trans is an M it's hard to see. Thank you in advance!
C70 = C700 Tilt Cab (gas).
D = 330 2V Heavy Duty FT engine.
G91141 = 1970.
175" Wheelbase.
M = Wimbledon White.
C700 Tilt Cab (gas), 24000 lbs. GVWR
118: 11 = Light Gray Crush Vinyl & Light Gray Blockweave Vinyl // 8 = 91A Standard Cab.
M = Clark model 285V 5 Speed Direct.
E34:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
4 = Ford 7,000 lbs. Capacity Front Axle without Power Steering.
24,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
17 = Washington DC Ford District Sales Office, where the original selling dealer ordered the truck from.
Old May 22, 2020 | 12:40 PM
  #279
Ten bus babe's Avatar
Ten bus babe
69 bus
Hey were trying to make sure what kind of engine is in our bus the we believe its a 390. The vin is B61DLF54368.
Old May 22, 2020 | 01:58 PM
  #280
Jayson Mark's Avatar
Jayson Mark
F800 VIN decode please?
Hey just wondering if anyone on here might be able to help me decode this vin number from our old f800 truck. We are mainly trying to figure out what year it is and which engine.
Any help is greatly appreciated, Thanks!
Old Jun 28, 2020 | 11:25 AM
  #281
RRAYMOND123's Avatar
RRAYMOND123
69 ford ? Can you decode this for me please
VIN# F61DRF31621
Old Jul 8, 2020 | 06:49 PM
  #282
KainParent's Avatar
KainParent
I got f700 vin N70EVC88772. looking to get decoded to find parts for it. thanks
Old Jul 8, 2020 | 07:06 PM
  #283
85e150's Avatar
85e150
Welcome to FTE!
I can't help you much other than to tell you that with a "N70..." VIN, you do not have an F700. It's an N or LN series truck.
See the link at the end of post 2:
https://www.ford-trucks.com/forums/1...lp-please.html
Old Jul 13, 2020 | 06:08 PM
  #284
Rowe Barn's Avatar
Rowe Barn
Vin decoder
Hi, I am trying to decode my Vin. I am mainly looking for information on what engine is in it it but any information would help. Thanks in advance Vin #N70DUG32199
Old Jul 14, 2020 | 03:36 PM
  #285
NumberDummy
I got a LN700 // VIN: N70EVC88772. looking to get decoded to find parts for it. thanks
N70 = LN700 (gas).
C88772 = 1976.
