Well I got the Title YEA!! But it has the same Vin# says the model is
LTCC6C Body type T8 Title was issued in 1982 so it was only 14 years old then and I doubt it would have been rusty doors as the reason? Who knows.
I have been looking into getting a Ford Tractor for over the road, but finding one with a decent rear gear/trans combo is a bit rough.
I have found a couple i like but there all across the US.
My question is do i have to ask you to decode each one? Which may or may not get annoying or is there a way i can look it all up myself? Even if i have to pay a little bit. I really need to be able to do 60-70 without the engine screaming so im running the trucks i find through a ratio calc to see what the engine RPM would be at. I have to know the Rear Gear Ratio and Trans final ratio tho.
The truck im looking at now has a trans code - PN, and a axle code - 63.
Would you happen to know what they are? Its for a 94 LT9000. The sale post just says 10spd eaton and its the 350hp 855 Cummins.
Hello, I am trying to decode the VIN to verify what the engine, trans, and rear axle are in this truck. I think its a 391 4V gas engine, 5 spd trans and some type of two speed rear axle with wedge brakes and air maxi cans. I'm guessing a late 70's truck?
O = Fuller model T905-B 5 speed Direct or New Process 542-FL 5 Speed Direct.
GBN:
GB = Eaton model 18221 Two Speed Rear Axle / 7.17/9.77 / 22,000 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
31,000 lbs. Gross Vehicle Weight Rating.
115150:
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
5150 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order. This makes it a Domestic Special Order.
Bill, Thank you very much for the quick reply. I have owned and still own many Louisvilles, most diesels, a couple gas ones and this one had me guessing for the year. I have resorted to used parts most of the time as most of the Ford big truck replacement parts in the Northeast US are getting very hard to find. I will post a parts question in the appropriate parts thread. Thanks again! Dano
