Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Mar 29, 2018 | 09:50 PM
  #166
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bradh21
F60DKE15597
F60 = F600 (gas).
D = 330 2V Heavy Duty FT engine.
K = Kansas City MO Assembly Plant.
E15597 = 1969.
Old Apr 7, 2018 | 05:21 PM
  #167
waterboyF60's Avatar
waterboyF60
Hello, could you please decode this vin its F60HVJA1260 also any info on GVR
GVWR has a 5-6 yard dump box on it.thanks
Old Apr 7, 2018 | 06:49 PM
  #168
NumberDummy
also any info on GVR // GVWR has a 5-6 yard dump box on it.
GVWR printed on the Certification Label (at the left center above Vehicle Identification Number), glued to the left door face below the latch.
F60 = F600 2WD (gas).
H = 370 2V or 4V
V = Kentucky Truck Assembly Plant.
JA1260 = 1980.
Old Apr 7, 2018 | 07:34 PM
  #169
waterboyF60
Thank you sir, I'll try to get the paint off the certification label,I don't understand why one would paint over it. From other research I think truck is under CDL without trailer, but do you think that this truck could pull a 580E backhoe with cdl or farm plate? Thanks
Old Apr 7, 2018 | 07:44 PM
  #170
waterboyF60
He sent me this from behind the seat so the GVRW is 20500 pounds and anything over 26001 pound is cdl. correct?
Old Apr 7, 2018 | 08:02 PM
  #171
85e150's Avatar
85e150
Over 26000. 26001 and up requires CDL. That backhoe weighs over 14000 lbs, so you would normally require a CDL. You mention a farm plate--if so, you are exempt within 150 miles of your farm. If you are out doing work for someone else, that won't fly.
SOS - Who Needs a CDL?
The truck will pull it, assuming good brakes on your trailer. But it will be so slow you should probably have a pilot and chase vehicle with lights and signs if there are any hills to climb.
Old Apr 7, 2018 | 08:08 PM
  #172
NumberDummy
Printed on the Certification Label: TYPE/GVW: F606 = 1980 F600 2WD (gas); 20,500 lbs. Gross Vehicle Weight Rating.
Old Apr 7, 2018 | 09:02 PM
  #173
waterboyF60
Thanks guys,commercial driver's license (CDL) not much for hills around here but good advice. Trailer and truck brakes will be 100% Farm plate probably wont fly, I'm not looking for work with backhoe but I do drive it from my house to my dads from time to time. Also he wants to gravel his driveway. Truck and hoe are from the 80's lol
Old Apr 16, 2018 | 10:02 PM
  #174
wendyq's Avatar
wendyq
Need help with this plate
Can someone decode what all of this info is?
Old Apr 17, 2018 | 05:48 AM
  #175
NumberDummy
Y90 = LTS900 (diesel).
This could be the number 1 or the letter I .. Who manufactured the diesel, as there are 3 possibles?
EE8453 = 1979.
203" Wheelbase.
J = Rangoon Red.
Y906 = LTS900 (diesel; 54,000 lbs. GVWR
H58: H5 = Tobacco Vinyl - Bostrom Levelair Seat // 8 = Standard or Custom Cab without Butterfly Hood.
U = Spicer model SST1007-3A 7 Speed Direct.
BJT:
BJ = Eaton model 38-DSC Single Speed Rear Axle / 4.88-1 / 38,000 lbs. Rear Axle Capacity.
T = Rockwell (Timken) model FL-901 18,000 lbs. Capacity Front Axle with Power Steering.
54,000 lbs. Gross Vehicle Weight Rating.
462339:
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
2339 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Apr 30, 2018 | 08:48 PM
  #176
Willie Sellit's Avatar
Willie Sellit
VIN DECODING
I am trying to decode Vin n66fv090911
Old Apr 30, 2018 | 10:22 PM
  #177
NumberDummy
Originally Posted by Willie Sellit
I am trying to decode VIN: N66FV090911
Verify this VIN, as there's no such thing as N66, no such thing as 090911.
It should be, depending on the year: O90991 or Q90991.
F = 391 4V FT engine // V = Kentucky Truck Assembly Plant.
Old Jun 26, 2018 | 07:38 PM
  #178
jjguyette's Avatar
jjguyette
Vin help
I’ve seen lots of people getting help with there vin codes. I can’t find anything online for this vin
Old Jun 27, 2018 | 11:05 AM
  #179
NumberDummy
Originally Posted by jjguyette
I’ve seen lots of people getting help with their VIN codes. I can’t find anything online for this VIN
F66 = F600 4WD (gas).
E = 361 2V or 4V FT engine.
CE0888 = 1978.
176" Wheelbase.
8 = Light Blue.
F661 = F600 4WD (gas), 24,000 lbs. GVWR
GA8: GA = Black H/D Vinyl // 8 = 81A Standard Conventional Cab.
M = Clark model 285V 5 Speed Direct.
55J:
55 = Rockwell model H170 Single Speed Rear Axle / 7.17-1 / 17,500 lbs. Rear Axle Capacity.
J = Ford 4,750 lbs. Capacity Front Axle without Power Steering or Ford 5,000 lbs. Capacity Front Axle with Power Steering.
24,000 lbs. Gross Vehicle Weight Rating.
768093:
76 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
8093 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Jun 28, 2018 | 09:43 AM
  #180
apocalypse09151211's Avatar
apocalypse09151211
Hello,
I recently bought a Ford F750. Trying to figure out what engine is in it. I'm thinking it's a 391. Here's the VIN F75FVA86839. Any help would be greatly appreciated.
Thanks,
Mark
