Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Jun 28, 2018 | 11:28 AM
  #181
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by apocalypse09151211
I recently bought a Ford F750. Trying to figure out what engine is in it. I'm thinking it's a 391.
VIN: F75FVA86839
F75 = F750 (gas).
F = 391 4V FT engine.
V = Kentucky Truck Assembly Plant.
A86839 = 1976.
Old Jun 28, 2018 | 11:31 AM
  #182
apocalypse09151211's Avatar
apocalypse09151211
Thanks for the reply!
Old Jul 11, 2018 | 02:29 PM
  #183
mrmuggles's Avatar
mrmuggles
Hello Everyone! I'm asking for your help in decoding this old COE truck. Any help greatly appreciated!
Old Jul 11, 2018 | 09:19 PM
  #184
NumberDummy
C80 = C800 (diesel).
Y = Cummins model C-180 464 cid 6 cylinder diesel.
U = Louisville KY Assembly Plant.
835024 = 1966.
111" Wheelbase.
COLOR code: Blank.
D802 = C800 (diesel), 27,500 lbs. GVWR
A91: A = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 91 = 91B Custom Cab.
TRANS code: Blank
5H = Eaton model 17800 or 17801 Two Speed Rear Axle / 5.57/7.60 / 18,500 lbs. Axle Capacity.
27,500 lbs. Gross Vehicle Weight Rating.
162 net HP @ 2,500 RPM.
720145:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0145 = Domestic Special Order number, truck prdedred special by the original purchaser, not "bought off the lot."
Truck was painted a non standard color and had a transmission installed that was a special order.
Old Jul 12, 2018 | 11:34 AM
  #185
mrmuggles's Avatar
mrmuggles
Y = Cummins model C-180 464 cid 5 cylinder diesel.
835024 = 1966.
111" Wheelbase.
COLOR code: Blank.
TRANS code: Blank
720145:
Thank you Very MUCH for this information. I appreciate your taking the time to help me! Best, JOE
Old Jul 18, 2018 | 05:04 PM
  #186
jmorgan88's Avatar
jmorgan88
I HAVE A 76 FORD C950 NEED HELP WITH VIN
THE VIN IS C95LUC72020 WOULD LIKE TO KNOW THE BREAKDOWN.
THANK YOU
Old Jul 21, 2018 | 02:41 PM
  #187
NumberDummy
Originally Posted by jmorgan88
VIN: C95LUC72020 .. WOULD LIKE TO KNOW THE BREAKDOWN.
Decoded in your thread in the 1973/79 forum.
Old Aug 6, 2018 | 01:28 PM
  #188
Fartin Dust's Avatar
Fartin Dust
Need help with a VIN Decode from an F700
F70DVN12439
Any help would be appreciated
Old Aug 20, 2018 | 07:24 PM
  #189
Richard Bain's Avatar
Richard Bain
Need help identifying what motor is in a F600 - Vin #F61EVCE1890
Old Aug 20, 2018 | 10:44 PM
  #190
third66go's Avatar
third66go
F70DVN12439 best guess:
F70 = F-700
D = 330-2V H.D.
V = Kentucky Truck Plant
N12439 = 1972 Model, built November 1971
Cheers
Old Aug 20, 2018 | 10:53 PM
  #191
third66go's Avatar
third66go
F61EVCE1890
Fourth position "E" should be a 361-2V if it is a 1968 model.
Are you sure the last "E" is accurate? Should be a number, and an 8 instead of an E would be correct for a 1968: C81890 = Jan. 1968.
Cheers
Old Aug 23, 2018 | 12:21 PM
  #192
Richard Bain
The F600 is a 1978 and the letter in question is a E.
Old Aug 23, 2018 | 08:53 PM
  #193
third66go's Avatar
third66go
Well, shucks, that changes things by 10 years...
"E" code motor in 1978 for F-600 should be a 361-4V X.D.
CE1890 is definitely a 1978 model.
Old Aug 23, 2018 | 08:58 PM
  #194
Richard Bain
Thank you very much
Old Aug 28, 2018 | 12:37 PM
  #195
NumberDummy
Originally Posted by Fartin Dust
Need help with a VIN Decode from an F700.
F70DVN12439
F70 = F700 (gas).
D = 330 2V Heavy Duty FT engine.
N12439 = 1972.
