Hello there. I just picked up an F600 snub nose as a project truck. I'm planning to mount the body on a new chassis/driveline combo. I would really appreciate any help decoding the VIN and the warranty plate info.
Thanks!
N61DUB00673 is the VIN
Wb: 163
Color: 6
Model: N615
Body: M81
Trans: L
Axle: G3D
Max GVW: 24 000
The next part of the warranty plate has some damage, can't read what these codes designate; ?64 and then 3800
Thanks very much for the response, I appreciate the info. I called it an F600 simply because that's the badging on the fenders. It's an old gravel truck that's been sitting in the back 40 of a farm for a fair while, so no registration or paperwork with model info came with it. Thanks again for the help!
The emblems should be: C7TZ-16720-E Right & C7TZ-16721-E Left .. FORD 600 Emblems / Obsolete
These emblems do not reflect F or N series trucks.
Hello all, new to the forum long time ford owner looking for help just bought a 19?? model f600 dump truck trying
to figure out what I have for sure. looked thru all of this post think I got some of it right but could use a little help.
Thanks in advance new to forums so hope I'm doing this right?
F60dvn20545
156 wheel base?
b
f605
b
a New process 435? reverse is to the left and back though not sure?
e2b
19200
64
3800
230600
Hello all, new to the forum long time ford owner looking for help just bought a 1972 F600 dump truck trying to figure out what I have for sure. looked thru all of this post think I got some of it right but could use a little help.
Thanks in advance, new to forums so hope I'm doing this right?
F60DVN20545 // WB: 156 / COLOR: B / MODEL: F605 / BODY: B8 / TRANS: A / AXLE: E2B / MAX GVW LBS: 19200 / CERT NET HP: 164 / RPM: 3800 / DSO: 230600
F60 = F600 2WD (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
N20545 = 1972.
156" Wheelbase.
B = Light Blue.
F605 = F600 2WD (gas), 19200 lbs. GVWR
B8: B = Light Blue & Medium Blue Vinyl / 8 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
E2B:
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
B = Ford 5,500 lbs. Capacity Front Axle.
19,200 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
230600:
23 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
0600 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Thank you so much you are awesome
NumberDummy do you know where I can find the vin on
the 73-79 model f600 other than the door? the door has been
changed looked on frame around right front wheel no luck.
Truck is registered by specific its VIN
Hidden frame VIN stamped atop the right frame rail partially under or ahead of the cab.
May be found below the alternator in the engine compartment.
Just purchased a 1972 F-600. Need the vin decoded please. Vin is F61ECN69935. Thanks!
Not sure you're still around, sorry you were overlooked. The VIN doesn't tell you much: vinwiz.com VIN Decoder
F61 = 1972 F600, gas 4x2
Engine code E: 361 2v FT V8
C = Ontario Truck Plant
N69935 = 1972 sequence
