Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Jun 14, 2023 | 03:26 AM
  #376
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 85e150
C60V5E29991
That does not work for 1955. It does work for 1969.
What engine is in it? A Y-block V8?
Anthonypapa22 typed S instead of 5 // See post #375
Old Aug 7, 2023 | 01:17 PM
  #377
Dalton67's Avatar
Dalton67
2nd Gear
I have a ford 750 with vin N75EVJ43722
I have a ford 750 truck I’m trying to get the vin decode N75EVJ43722
Old Aug 7, 2023 | 03:57 PM
  #378
85e150's Avatar
85e150
Welcome to FTE!
N75 = LN750
E = 361 2V FT gas V8
V = Kentucky Truck Plant
J43722 = 1970 numerical series, June 1970 production
If you have a picture of the warranty plate we can find the axle and transmission codes along with some other info.
Old Oct 1, 2023 | 10:33 AM
  #379
Dalton67's Avatar
Dalton67
2nd Gear
Where do I find that warranty plate?
Old Oct 1, 2023 | 11:16 AM
  #380
85e150's Avatar
85e150
Driver door near the latch.
Old Dec 30, 2023 | 04:43 PM
  #381
Tedrick1's Avatar
Tedrick1
4th Gear
1971 ford bucket truck.
Hey y’all, having some trouble narrowing everything down on this one. vin is below, all help would be appreciated.
N70EVK31323
Old Dec 31, 2023 | 12:11 AM
  #382
85e150's Avatar
85e150
Welcome to FTE!
VIN doesn't say much but here's what it will tell you:
N70 = LN700 gas
K31323 = 1971 numerical series, October 1970 production
Old Nov 19, 2024 | 08:53 PM
  #383
Zac124's Avatar
Zac124
1st Gear
Having a tough time decoding this vin for my 1967 f600 dump truck. Would you be able to tell me what it is?
F61CEB42618
Old Nov 20, 2024 | 04:38 PM
  #384
85e150's Avatar
85e150
Welcome to FTE!
F61CEB42618
F61 = F600 gas, 4x2
C = 330 2V MD FT gas V8 (Medium Duty = FE cast crank, FE oil pump/distributor drive/possibly FE water pump, different flywheel than other FT engines)
E = Mahwah Assembly Plant
B42618 = 1967 numerical series, June 1967 production. (This number is also part of the 1976 numerical series. However, by '76 only the Kentucky Truck Plant (code V) or Ontario (Code C) would show)
If you still have the original warranty plate on the driver door, that info can be decoded as well.
Old Apr 13, 2026 | 05:35 PM
  #385
bolo1188's Avatar
bolo1188
1st Gear
1977 fire truck
Can you please decode the VIN for a 1977 Fire Truck C91LV065133? Reading here, it looks like gas V8, title has diesel listed.
Old Apr 13, 2026 | 07:48 PM
  #386
asavage's Avatar
asavage
FTE Community Team
C91 L V O65133
C91 = for '75-on: C900--gas
L = well, you have your choice of three diesel and one gas engine . . . but, because "C91" is explicitly a gas model designation, you're left with the Superduty 534 / 8.8l V8.
V = Kentucky truck plant
O65133 = 1977 numerical series, Nov1976 production
Old Apr 20, 2026 | 03:38 PM
  #387
sjrobins99's Avatar
sjrobins99
5th Gear
LT900 VIN help
Hello
Can anyone help me with this decoding truck. I specifically am trying to determine the drive axle info.
U90TVM13434
186
LS
U900
AE2
R
CVS
57000
236
1750
150770
Old Apr 20, 2026 | 05:33 PM
  #388
asavage's Avatar
asavage
FTE Community Team
U90TVM13434
U90 = LT900 Diesel
T = Detroit 8V-71N, 568 ci
M13434 = 1971 numerical series, Jul1971 production
186 = 186" wheelbase
LS = Dark Green AE60-1237-A, Lime Gold Mettalic (but no part No.)? For 1971 this is listed only for the Canadian trucks.
U900 = LT900, 43,000 GVW
AE2
AE = Medium Gray vinyl
2 = Custom cab w/butterfly hood, "81B"
R = Fuller RT-610 10-speed, direct
CVS
CV =
  • Forward rear = Eaton 42DP
  • Rear rear = Eaton 42RP
  • Both 5.05:1 ratio, 44,000 lbs
S = Rockwell (Timken) FH-901, 16,000 lbs.
57000 = 57,000 GVW
236 = net 236 HP @ 1750 RPM
150770
15 = Newark district
0770 = Special order number
Old May 8, 2026 | 06:00 AM
  #389
voicelessoptimal's Avatar
voicelessoptimal
4th Gear
That VIN is really old
I tried to run it on https://vinnumber.net/makes/ford/ and also got no results
Old May 8, 2026 | 10:01 AM
  #390
asavage's Avatar
asavage
FTE Community Team
Most VIN checkers won't work with anything before 1981, when VIN format became standardized in the US, and use 17 characters.
