11 digit Vin decode
F61 = 1973 on F600 gas 4x2
E = 361 2V XD FT series gas V8. (XD similar to HD designation)
C = Ontario Truck Plant. (the MPC says everything was built in Kentucky after 9/69 but this is a Canadian market truck so Ontario makes some sense.)
A51773 = 1976 series number. (This number also works for 1967 but you have a dentside cab and the model number/GVWR does not match '67)
176 = 176 inch wheelbase
M = White
F611 = '73-'79 F600 gas 4x2 20,200lbs GVWR (for 1967 the info is the same but GVWR would be 22,000lbs)
GA8 = I do not have upholstery info, but looks like Custom Cab.
A = New Process model 435 four speed transmission
62L
62 = Rockwell (Timken) model F-106 single speed rear axle, 15,000lbs capacity, 6.20 ratio
L = Ford front axle, 6,000lbs capacity with power steering
20200 = 20.200lbs GVWR
B1 = Ford of Canada, Central (Ford) district
Pretty clear it was repainted, if anything else doesn't match up, let me know.
As to parts interchange, probably multiple years between at least '73-79.
Look at the links in post 13:
https://www.ford-trucks.com/forums/1...l#post18247474
Search by the Ford part numbers highlighted in blue here, and you will find several for sale:
https://www.ford-trucks.com/forums/1...74-f600-2.html
VIN is N80FVP90442
Title states 1973 with a scale weight of 10860
Any help appreciated; I have a ton of work to get it completely road worthy..............mostly minor
Paul
N80 = LN800 gas
F = 391 4V gas FT V8
V = Kentucky Truck Plant
P90442 = 1972 numerical series.
Is there a warranty tag rivited to the driver door? That has axle codes etc on it.
P9---would indicate late production. Some states would title it by the first year sold which very well could have been 1973. If the other stuff matches you should be good.
Concerns are wheels--widow maker types were still out there, and brakes--drums are not available new, impossible to find used. Pulling a trailer and backhoe you will want the trailer brakes to be 150%.
Right away I noticed this truck isn't the right vehicle for towing. Changes my plans slightly; I am not going to use it pulling the trailer etc....too much weight. Mostly for gravel runs and figure the backhoe can drive itself where I am going.
Your description of Widow Maker wheels has me worried though..............what are they? Got a picture to reference?
Thanks,
Paul
VIN T85KUC16279
WB 158
Color L
Model T852
D
814N
B8G
Max GVW - 41000
Net HP - 222
RPM - 3200
440123
Thank you for your help
T85 Conventional Cab, Gasoline
K 477 cu. in., 4 barrel carb (Super Duty V-8)
U Louisville Truck Plant
C16279 1968 model year serial no.
158 Wheelbase (front axle to midpoint of tandem axles)
L Exterior color ??
T852 41,000 lb GVW Rating
D Beige woven plastic/vinyl with foam cushion
81 Conventional 2-door cab
4 Aux. trans. 3 speed HD Spicer 2.14/1.00/.86 ratios
N Main trans. 5 speed Spicer 6352, iron case
B8 Rockwell tandem rear axles 6.83 ratio SLHDA front/SLHDR rear, 34,000 lb rated
G Rockwell/Timken FF-903 12,000 lb front axle
U80 = LT 800 diesel (Tandem axles)
D = Caterpillar V225 - 3208 636 CID 8 cylinder diesel OR Cummins KT450 1150 CID 6 cylinder diesel (Both engines use that same code for '79)
EG9517 = 1979 numerical sequence
removed from dash board in font of the steering wheel...i am glad you continue to carry on your eval's for us neophytes...please let me know what you understand about this id plate...thank you, stephen b clark rye nh
vid #P35BLC88979 it is from a 1968± ford/grumman step van, formerly a nissan bread truck...
thank you sbc
