Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Feb 5, 2018 | 03:28 PM
  #151
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dano L9000s
Bill, This is the data plate from a 1974 LT9000 I am restoring. I have not been able to decode the rear axle code. Thanks, Dano
I cannot decode it either, probably because the rear axle was a Domestic Special Order* w/a 6 digit DSO code (110014).
The first 2 refer to the district sales office (11 = Boston). The last 4 refer to the DSO invoice number.
AXLE code usually contains 3 digits. The first 2 refer to the rear axle, while the 3rd refers to the front axle.
P is probably the front axle code: Rockwell-Timken model FF-903 Front Axle, 12,000 lbs. Capacity with Power Steering.
*Domestic Special Order: Something was installed on the truck that was not an RPO (Regular Production Order). No part numbers for parts listed in the catalog.
If parts were required, the dealer contacted FoMoCo w/6 digit DSO. They looked up the order number, passed the part numbers/sources back to the dealer.
Old Feb 5, 2018 | 05:33 PM
  #152
Dano L9000s's Avatar
Dano L9000s
Smile
Bill, Thanks for the explanation. If the truck was ordered with the owner/operator package or trim options like the aluminum fuel tanks and stainless steel mirror frames and stainless exhaust mufflers for the 8V71 Detroit would any of that show as a trim code on the door tag or would that only be on record with the DSO code with some file that probably no longer exists? Thanks, Dano
  #153
1974F700's Avatar
1974F700
Picture of Door ID Tag 1974? Ford F700
Old Feb 5, 2018 | 07:00 PM
  #154
NumberDummy
Bill, Thanks for the explanation. If the truck was ordered with the owner/operator package or trim options like the aluminum fuel tanks and stainless steel mirror frames and stainless exhaust mufflers for the 8V71 Detroit, would any of that show as a trim code on the door tag or would that only be on record with the DSO code with some file that probably no longer exists? Thanks, Dano
There's no trim code on the Warranty Plates of these trucks.
There's a BODY code, but it only refers to the type/color of the seat upholstery and if the truck is a Standard or Custom Cab.
There's no way to know today what Domestic Special Order parts were installed.
Kevin Marti, a Phoenix AZ Mustang/Shelby "nut" acquired all the 1967/79 records in the late 1980's, when he discovered that FoMoCo was going to THROW THEM AWAY, but...
He hasn't done anything with the 500 and larger series truck records, so you cannot get a "Marti Report" like you can for cars, F100/350's, Bronco's and Econolines.
Old Feb 5, 2018 | 07:16 PM
  #155
1974F700's Avatar
1974F700
Warranty Plate pic
This plate cannot be used to decode your truck. Since I cannot see a clear pic of it, it's either a "buck" tag or it's attached to the owners card.
What I need to see is a pic of the Warranty Plate: Riveted to the left door face below the latch.
Old Feb 5, 2018 | 08:03 PM
  #156
NumberDummy
Warranty Plate pic...
I didn't miss it (post #153 originally)...it'll be decoded shortly. I take 'em in turn, plus I type in...at least 7 other forums.
Old Feb 6, 2018 | 10:09 AM
  #157
NumberDummy
Originally Posted by 1974F700
F70 = F700 (gas or diesel).
W = 361 2V FT low propane gas engine (Domestic Special Order) or Cummins NTC290 855 cid 6 cylinder diesel.
V = Kentucky Truck Assembly Plant.
T47216 = 1974.
158" Wheelbase.
COLOR: Blank.*
TYPE/GVW F703 = F700 (gas or diesel), 23,000 lbs. GVWR
BODY 228: 22 = Medium Blue Vinyl / 8 = 81A Standard Cab.
TRANS 2 = Clark model 282V 5 Speed Direct.
AXLE = This is hard to read, it appears to be: E3M
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
23,000 lbs. Gross Vehicle Weight Rating.
DSO 260149.
26 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
0149 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color, making it a Domestic Special Order.
The propane gas engine (if so equipped) is also a Domestic Special Order.
Old Feb 16, 2018 | 10:08 PM
  #158
Dano L9000s
Smile Early 70's Ford 9000
Hello Bill, Could you please decode the attached doortag when you have time. Its from an early 70's LT9000 tractor in my yard. Thank You, Dano
Old Mar 7, 2018 | 10:13 PM
  #159
Shidorilince's Avatar
Shidorilince
I need help to decode this Vin
"AF1JJR32725"
PLEASE
she's Mexican
Old Mar 7, 2018 | 10:29 PM
  #160
NumberDummy
Decoded in post #736 in the "If you need any info" thread.
Old Mar 7, 2018 | 10:31 PM
  #161
NumberDummy
Originally Posted by Shidorilince
I need help to decode this VIN "AF1JJR32725"
PLEASE, she's Mexican
I cannot help you, this 11 digit VIN is different than the US/Canadian VIN's used thru 1980. I would need a Mexican Ford parts catalog to decode it, but I don't have any.
Old Mar 21, 2018 | 04:09 PM
  #162
Dave588's Avatar
Dave588
How about an 11 digit vin for a 1970 F8000 louisville cab?R804VH84277
Old Mar 26, 2018 | 10:08 AM
  #163
NumberDummy
Originally Posted by Dave588
How about an 11 digit VIN for a 1970 F8000 Louisville cab? R804VH84277
R80 = F800 (diesel). F8000 is an F800 w/a diesel engine.
4 = Caterpillar model 200 8 Cylinder 573 cid Diesel Engine.
H84277 = 1970.
Old Mar 29, 2018 | 03:27 AM
  #164
bradh21's Avatar
bradh21
Could use some VIN decode help!!!!
F60DKE15597
help please.
Old Mar 29, 2018 | 12:37 PM
  #165
bradh21's Avatar
bradh21
I see you ALL OVER this forum!!!! Would you please help me with my VIN?? F60DKE15597
I'm having issues with identifying the year and the engine code. "D?" Not sure what that engine is or its history. I sure would appreciate your help.
Brad Hanks
