Coleman lantern
Old Apr 6, 2014 | 04:29 PM
  #271
wpnaes's Avatar
wpnaes
Yeah, those are only available used, so you'd have to refill them. I tried it, but with no luck. The rubber gets hard after 20 yrs and breaks easily.
Here's a few ideas: see post 96, 112, 126.
Old Apr 6, 2014 | 04:48 PM
  #272
SpringerPop's Avatar
SpringerPop
Originally Posted by wpnaes
That large cap is for storage; mantles. Genny, wrench and such.
So, that's a "parts well", like the military models?
Do I then see a fill cap around on the far side?
Performance-checked all four of mine today. All are bright-burners without leaks. Although the ball-check leaks slightly on my 3-60 228E, it's solid as a rock when the pump valve is tightened.
The Dietz and Kirkman kero's are also completely operational, but that's beyond the scope of this thread.
Pop
Old Apr 6, 2014 | 05:05 PM
  #273
wpnaes's Avatar
wpnaes
Pop
Yes and Yes.
See my post 85 pic when it was apart.
Old Apr 6, 2014 | 11:51 PM
  #274
OldBlackCat's Avatar
OldBlackCat
Pop
let me know pop if you want to borrow the tool i have to remove that check valve.
i picked up one a few months back and it was one of the best investments yet!
Old Apr 7, 2014 | 03:18 AM
  #275
SpringerPop
I may do that, Justin.
I'll take it out and see if it's just a bit of leather hanging the ball or not.
I have a new check valve to install if that's the problem.
Pop
Old Apr 11, 2014 | 07:46 PM
  #276
wpnaes's Avatar
wpnaes
Fixed up a Sears big hat recently. Decided not to paint it. Last pic tells a sad story...
Finally put the leaky fount in post 71 under the knife.
Old Apr 14, 2014 | 03:16 PM
  #277
OldBlackCat
Picked up a Coleman 290 from Craigslist yesterday, listed as $35 or best offer with the red carry case in the background..... guy dint whine and moan when i offered $30....sigh i should of said 15 bucks....
came with a few extra mantles, and a bit of fuel in the fount. when i got over to my buddy's house i cleaned the globe and lit it right up! ran a little dim, so i cleaned the generator which was a pain in the ***. had to practically disassemble the whole lantern.
oh well here is a picture. its also dated 3/86 so is the case.
Old Apr 14, 2014 | 07:24 PM
  #278
SpringerPop
Functionally, how is that different from a 220?
Frosted globe and paint color?
Pop
Old Apr 14, 2014 | 09:37 PM
  #279
OldBlackCat
has rubber neoprene pump cup, no cleaning lever, and the fuel valve is adjustable with the valve core inside. unlike the 220s where the valve is a needle and seat.
Old Apr 15, 2014 | 11:43 AM
  #280
SpringerPop
No cleaning lever?
So, one just has to replace the generator if the orifice gets clogged.........
What will they think of next?
Pop
Old Apr 15, 2014 | 12:10 PM
  #281
OldBlackCat
it still has the cleaning tip..... you rotate the **** from off to on rapidly to work it.
Old Apr 16, 2014 | 10:14 AM
  #282
wpnaes's Avatar
wpnaes
A 200a and 333 from the Desert.
Old Apr 16, 2014 | 10:16 AM
  #283
wpnaes's Avatar
wpnaes
Out by Old Dale Rd.
Old Apr 16, 2014 | 10:19 AM
  #284
wpnaes's Avatar
wpnaes
A great idea; on BLM.
Old Apr 16, 2014 | 11:44 AM
  #285
SpringerPop
Somebody's ashes?
Pop
