Coleman lantern
Old Feb 17, 2014 | 12:25 PM
  #211
wpnaes's Avatar
wpnaes
Dagnabit!
7 foot fall, original 1948 green letter globe!
Old Feb 17, 2014 | 01:06 PM
  #212
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Bummer
Old Feb 17, 2014 | 08:48 PM
  #213
OldBlackCat's Avatar
OldBlackCat
that sucks....
Old Feb 17, 2014 | 08:54 PM
  #214
wpnaes's Avatar
wpnaes
Gotta laugh at myself sometimes. Keep yur perspective and don't rush a job.
I see the check valve tool is back, but I like the idea of fixing the old one.
https://www.oldcolemanparts.com/prod...79&cat=&page=1
Old Feb 17, 2014 | 08:56 PM
  #215
OldBlackCat
outch on that tool. id hurry up and order a new one from OCP if you can. i heard a rumor that hes either running low or out of them and has no one making them anymore.
Old Feb 17, 2014 | 09:03 PM
  #216
OldBlackCat
not exactly coleman lantern.... but it is gas pressure!
1950's ish gasoline blowtorch made by clayton lampert. its about 95% brass.....
i dont have a good picture of it but i do have a picture of it running which you dont see too ofton. got it tore apart right now for cleaning and polishing. i also got a set of soldering irons for it too i need to pick up from a friend.
Old Feb 17, 2014 | 09:14 PM
  #217
wpnaes's Avatar
wpnaes
Very cool torch, for pipe sweating?
I may gave to return to my old method of removal with an oversize screwdriver and a ton of downward pressure.
Old Feb 18, 2014 | 12:06 AM
  #218
OldBlackCat
torch is for what ever use you may need heat for.....plumbers and pipes, electriciansand soldering there wires, mechanic and heating up bolts, etc
Old Feb 18, 2014 | 12:15 AM
  #219
SpringerPop's Avatar
SpringerPop
Sean, I would think that a careful application of a grinder or file would restore that tip on the puller.
Is it the type that has long threaded rods to keep the tip mated to the valve during removal?
Pop
Old Feb 18, 2014 | 12:19 AM
  #220
OldBlackCat
the tool itself is a little long..... id bet a machine shop could re mill the end.....
Old Feb 18, 2014 | 04:14 AM
  #221
wpnaes's Avatar
wpnaes
Pop
Yes it is Pop. Good ideas guys, thx.
Old Mar 3, 2014 | 01:33 AM
  #222
OldBlackCat
so i bought a lantern from a member on another forum.... about 2 weeks later i get it in the mail..... smashed, the globe was packed in another box with the lantern and it was turned to bits.
fast forward to today, i got tired of looking at a bent lantern on my desk so i got to straitening the burner cage with a little brute force.
then i took the whole thing apart and gave all the tranished brass a nice vinegar bath followed up with some 0000 steel wool and mothers mag and aluminum polish.
put the whole mess back together and lit it up! its been running for the last 3 hours out on the porch with no apparent problems
now i just need to order a new globe.
Old Mar 3, 2014 | 02:13 AM
  #223
SpringerPop
So get a globe for it!
One errant, suicidal moth will put a nice hole in a mantle.
Pop
Old Mar 3, 2014 | 02:22 AM
  #224
Greywolf's Avatar
Greywolf
Those things are just plain cool -provided you get the mantles to fit.
More light than anything I have ever seen - Edison would have loved them!
Old Mar 3, 2014 | 02:29 AM
  #225
OldBlackCat
ill get one as soon as i can pop.... works been in the crapper again. cleaning and polishing with stuff i have in stock already is free and passes time while i do side jobs and hopefully get a phone call for a union apprenticeship.
next up for fixing up is a Coleman 275A "aka a turd" and a "Frankie" lantern i built up.... its a smash up of a Coleman 200A and a Coleman 220.
