1978 - 1996 Big Bronco
Operation: Zebra build
Old Jan 3, 2012 | 06:05 PM
  #271
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
By the time you are done it will be brand new 1995 Bronco.
Jim
  #272
Jigger2020's Avatar
Jigger2020
Right on Brett, I love to see the proper parts, I guess you do too, G
Old Jan 3, 2012 | 07:30 PM
  #273
mpc07005's Avatar
mpc07005
Finally. (This was ~2 pages shorter when I started) Looks great! That creeper must roll on everything. I wish I didn't have the Sears special with 1" wheels.
  #274
Edgethis's Avatar
Edgethis
Thanks guys! I do like to have proper parts. I cut corners on my 06 Ranger when I bagged it, it's been nothing but problems since. I figure ill take my time on the Bronco and get the right parts because I only wanna do something once.
Old Jan 3, 2012 | 07:37 PM
  #275
Encho's Avatar
Encho
The Southernmost Mod
You and i are on the same page, doing it right means you won't have issues for a long while.
Old Jan 3, 2012 | 08:40 PM
  #276
Edgethis's Avatar
Edgethis
Those creepers are amazing. They have like 4"lift wheels.
Thanks Encho, I want this truck to last a long time
Old Jan 3, 2012 | 09:07 PM
  #277
GruesomeJeans's Avatar
GruesomeJeans
Looks great, are you planning to do the studs yourself? Mind doing a step by step on it cause i got one broked up one and don't really want to sped the money to have it done BUT I have been told that dealing with the 4wd hubs is a big PITA so i am kind of on the fence Besides i just spent $954 on the Green Machine so i need to save a bit
Old Jan 3, 2012 | 09:14 PM
  #278
Edgethis's Avatar
Edgethis
I do plan to do them myself. I will take plenty of pictures for your guys viewing pleasure.
Old Jan 3, 2012 | 09:17 PM
  #279
GruesomeJeans
Ok good so are they going on the front or all around or??
Old Jan 3, 2012 | 09:58 PM
  #280
Edgethis's Avatar
Edgethis
Unless you've been hanging around that oddball GMC Quadratrac, Trucks only have spindles up front . you may have these mixed up with wheels studs, same thing just in a different spot.
Old Jan 3, 2012 | 10:14 PM
  #281
Edgethis's Avatar
Edgethis
Spindle Stud install.
Here's the tools I used. A nice set of vice grips and a ratchet with a deepwell 18mm socket.
http://www.flickr.com/photos/62639173@N03/6632447757/http://www.flickr.com/photos/62639173@N03/6632447757/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Insert the stud from the rear. Make sure the flat edge is lined up with the axle shaft hole.
http://www.flickr.com/photos/62639173@N03/6632450359/http://www.flickr.com/photos/62639173@N03/6632450359/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Hold the stud in place with the vice grips:
http://www.flickr.com/photos/62639173@N03/6632450963/http://www.flickr.com/photos/62639173@N03/6632450963/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Ratchet away on the nut:
http://www.flickr.com/photos/62639173@N03/6632450579/http://www.flickr.com/photos/62639173@N03/6632450579/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Keep going until the nut rests against the knuckle, it will pull the stud into the knuckle so make sure you hold the pliers right, keeping the flat spot towards the hole.
http://www.flickr.com/photos/62639173@N03/6632453193/http://www.flickr.com/photos/62639173@N03/6632453193/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Repeat until complete!
http://www.flickr.com/photos/62639173@N03/6632452435/http://www.flickr.com/photos/62639173@N03/6632452435/ by http://www.flickr.com/people/62639173@N03/, on Flickr
This is much easier with the knuckle out of the truck, but most studs can be done with it on the truck. The ball joints may get in the way, thats why some are harder to do while on the truck.
Lug/wheel studs can be done with the same process. Old studs can be tapped (NOT SMASHED) out with a hammer, preferable with a brass punch. Make sure you use plenty of Penetrating oil.
Old Jan 3, 2012 | 10:16 PM
  #282
Edgethis's Avatar
Edgethis
Just found out/realized that my new U-joints may not work.
They won't fit through the hole flat. I got the "Brute Force" style because they are supposed to be tougher, not require greasing. Might have to check and swap them out for regular joints. I'm really glad I found this out now, and not with the Zebra torn apart.....
Old Jan 3, 2012 | 10:54 PM
  #283
Encho's Avatar
Encho
Get the Spicer ones, 570x i think, and be done with it, if you by any chance prefer a greaseable u-joint (they last a lot more if properly maintained, and should be the choice if you intend to drive through any water) get the precision 377 u-joints.
Also, you might still be able to use the u-joints you bought but the axle could require a little coercion to go in.
Old Jan 3, 2012 | 11:35 PM
  #284
GruesomeJeans
Holy moly, i didn't know those were for spindles. Also on an off note i do somewhat hang around GMs quadracraps, I have to wash them now and again. When i had my wheels off today i was looking around at the studs and I think i saw one bent but i can't be sure, I didn't get a good look cause i was trying to stay our of the way. So far i haven't had any problems but I would like to have 5 studs over 4 with 35s...
Old Jan 3, 2012 | 11:42 PM
  #285
Edgethis's Avatar
Edgethis
Well to replace the wheel studs you need to pull the rotor/hub assembly. Then tap it out and put a new one in.
