1978 - 1996 Big Bronco
Operation: Zebra build
Old Jan 2, 2012 | 12:24 PM
  #256
Edgethis's Avatar
Edgethis
Originally Posted by SideWinder4.9l
That looks AWESOME.....
Btw, what sorta paint are you using?
CARC:
What is CARC paint? CARC stands for Chemical Agent Resistant Coatings. These coatings are used extensively on most military vehicles and equipment. These coatings produce a non-porous coat that impedes radioactivity, chemical and biological contaminants from penetrating the coating and the base material. Instead of penetrating the coating, chemicals bead up on the exterior of the surface and are washed off easily.
CARC is required to resist chemical attack from aggressive cleaning detergents used for decontamination of vehicles. In turn, these vehicles can be used over again without the concern of future contaminants along with the security of resisting further chemical attack.
I have some laying around.
iIs made by Sherwin Williams, I plan on talking to them this week and seeing how much it is for more (pints/gallons) and also what colors they can make it in. I have a few other guys interested in using it.
Old Jan 2, 2012 | 01:16 PM
  #257
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Looking good as usual. I still think you should paint them Zebra striped tho.
Jim
Old Jan 2, 2012 | 01:24 PM
  #258
ErrorS's Avatar
ErrorS
Just curious, why did you decide to keep your swaybar? I barely noticed when I took mine off with stock springs. Especially with the rough country springs and quad shocks. Deavers + current shock setup is a whole other story though..
Old Jan 2, 2012 | 04:13 PM
  #259
Skip1970's Avatar
Skip1970
probably for them highspeed turns.
Old Jan 2, 2012 | 05:59 PM
  #260
Edgethis's Avatar
Edgethis
Its a high performance machine as Ace Ventura said.
I decided I didn't really wanna lift the truck, so I want everything running in tip-top shape.
I've heard some people say that it did nothing and others have said that it is night and day. I'll find out I guess.
Old Jan 2, 2012 | 07:18 PM
  #261
ErrorS's Avatar
ErrorS
Of course there is absolutely no reason to remove them unless you plan on doing a lot of offroading.
Old Jan 2, 2012 | 07:24 PM
  #262
Nighteyez's Avatar
Nighteyez
Or lifting the truck and rock crawling
Jim
Old Jan 2, 2012 | 09:04 PM
  #263
GruesomeJeans's Avatar
GruesomeJeans
It looks good, that CARC is somethin else. Does it come in spry paint cans? That would be cool if they had a Ford Blue that i could get and do up my oil pan in it.
Old Jan 2, 2012 | 09:39 PM
  #264
Edgethis's Avatar
Edgethis
Nope, not that I know of. It is really thick.
Old Jan 2, 2012 | 11:11 PM
  #265
GruesomeJeans
Oh thats kind of a bummer, I don't have a spray gun...
Old Jan 3, 2012 | 12:10 PM
  #266
Edgethis's Avatar
Edgethis
I actually brush the CARC on, I spray a quick primer coat and brush two thin coats of CARC on.
Sadly after ordering incorrect bushings and getting blank stares I decided that this isn't something the local parts stores can get. Autozone had the bushing, but it was a special order and was a cheap brand (rubber at that)
SO I placed an Order from RockAuto for a Moog set that comes with new bracket, that seems to have been the snagging point for me. All the bushing I seem to get are too tall for the stock brackets. Naturally Ford has discontinued the bushing as well
Here's the part I ordered:
http://info.rockauto.com/getimage/ge.../K8791_TOP.jpg
Till next time guys!
Old Jan 3, 2012 | 12:13 PM
  #267
SideWinder4.9l's Avatar
SideWinder4.9l
So you're saying that taking a few measurements, and putting the Polyurethane bushing to a belt sander is too much?
Old Jan 3, 2012 | 12:46 PM
  #268
Edgethis's Avatar
Edgethis
I wish it was that easy. I can't get then to fit the bracket at all. Too tall and too skinny. So I figure a new bracket/bushing set is the best choice.
Old Jan 3, 2012 | 01:07 PM
  #269
SideWinder4.9l
Hmmmm....Now that is a horse of a different color now, isn't it?
Old Jan 3, 2012 | 04:03 PM
  #270
Edgethis's Avatar
Edgethis
Just got a visit from the UPS man
http://www.flickr.com/photos/62639173@N03/6630660087/http://www.flickr.com/photos/62639173@N03/6630660087/ by http://www.flickr.com/people/62639173@N03/, on Flickr
I have quite a stack of parts piling up for the Bronco. Hope to have time soon to install some of them
The spindle studs are definitely longer then stock, but the Mike's Parts claim it won't interfere in anything. Worst case if they do, then I can cut then down once the spindle is installed.
