1978 - 1996 Big Bronco
Operation: Zebra build
Old Dec 23, 2011 | 10:44 AM
  #226
SideWinder4.9l's Avatar
SideWinder4.9l
Originally Posted by Edgethis
I actually called moog. They told me its just a synthetic grease with "Molly" in it. The guys at Advance helped mr look through every tube they had till we found 2a that specifically listed with Molly. Both were Valvoline. I chooses one and guess what? Is was discontinued so i got the tube for a nickle.
One GOOD thing, about Advance Auto....
Old Dec 26, 2011 | 05:11 PM
  #227
Edgethis's Avatar
Edgethis
OK, not much new but I did do some research on the Saginaw swap. I took a list of Part numbers to my friendly Advance and we plugged them all in. I got one to come up. It is a Napa part number and their website shows that as the fabled Cardone 20-6244 (custom made 100% bolt on to the stock set-up). So I will wait and see in the morning what comes in. If it is the right one then it shows they have 6 available in their regional warehouse. I'll let you guys know.
Old Dec 26, 2011 | 05:24 PM
  #228
Jigger2020's Avatar
Jigger2020
Well done Brett & great work there, looks nice & clean too, Gig
Old Dec 26, 2011 | 05:47 PM
  #229
Anafiel's Avatar
Anafiel
Yup, let us know, and also the part numbers to go with it!
Thanks
Old Dec 27, 2011 | 07:59 AM
  #230
Edgethis's Avatar
Edgethis
OK, well the advance part number didn't work out. But they did help me look and we found that Napa still lists that pump. I went to Napa and inquired. He said that the part number isn't superseded by anything else and it doesn't say that it's discontinued. He is going to call the warehouse to check this morning. Fingers crossed. if not, I'm just gonna have to get a regular replacement.
Old Dec 27, 2011 | 08:21 AM
  #231
ErrorS's Avatar
ErrorS
I gotta tell ya, everyone is buying those Saginaw's new, then spending money on the brackets at a junk yard, buying new hoses.. I think they're just overcomplicating the swap. My local yard sold me some old, ugly, greasy pump, hose and bracket for $30. Dumped the fluid in the pump, put fresh fluid in, bolted it on, reused the hose off of the pump I bought and it's just fine.
I don't think these Saginaw pumps go bad for anything.. and in my experience, these old Ford parts are better than anything you can buy new right now.
Just a suggestion ,start with a used pump + bracket, as most yards will charge you the same for both anyways (big aluminum bracket), you're still gonna need the pulley, put the one from the junkyard in and I'd bet it would be fine.
Oh yeah, I also buy this uh .. green? grease from Autozone that I've been pretty happy with so far, $7 a tube I think.
Old Dec 27, 2011 | 08:26 AM
  #232
Edgethis's Avatar
Edgethis
I wish. There are no local junkyards that let me wander around. And when I ask them for something they just look like a deer in the headlights and say they don't have that vehicle.
However, if you happen to go to your local junkyard sometime and see this bracket with/without a pump. I'd be willing to buy it off you if you'd ship it to me.
Old Dec 27, 2011 | 08:59 AM
  #233
ErrorS's Avatar
ErrorS
They do that to me here when I ask about Broncos, tis a rare thing to see a Bronco in a junkyard here nowadays.. and the weather here is terrible right now, I wont be going to a junkyard for a while.
I know for a while you could find a pump that looked like the Saginaw at Advanceauto, but I was told by someone that it's lower pressure than the Saginaw and has an aluminum impeller like our stock pumps, but just uses the metal reservoir, which is why I just stuck with the used pump.
It's a great swap anyways, you wont be disappointed.
Old Dec 27, 2011 | 05:26 PM
  #234
Edgethis's Avatar
Edgethis
OK so, Napa called and said that they can't get that pump. i figured, but wanted to try. Anyways, I dug through some racing sites and found this stuff. Anyone heard about it or have any input? They say it'll fit only up to a 92...any idea why?
Ford 289/302/351W Saginaw P/S Pump Bracket - Power Steering Conversion Kits - Ford Bronco 66-96 - Vehicle Specific Products
Ford 351 Saginaw Pump Adapter Bracket-MB14K : Pump Systems and Components, Mount Brackets | PSC Motorsports - performance steering components
^^ bracket to be used with this pump:
80 & newer Standard P Series Pump with Remote Can-SP1305 : Pump Systems and Components, GM | PSC Motorsports - performance steering components
Thanks for looking/any input
Old Dec 27, 2011 | 06:37 PM
  #235
Edgethis's Avatar
Edgethis
Guys!! I think I may have found a bracket to mount a Saginaw!!
Check out this thread!
https://www.ford-trucks.com/forums/1...p-bracket.html
Old Dec 27, 2011 | 08:02 PM
  #236
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Good Deal!!!
Jim
Old Dec 30, 2011 | 05:17 PM
  #237
Edgethis's Avatar
Edgethis
Got some new parts I'm getting ready to put on. I got a good deal on the sway bar links and the u-joints, got all 3 joints and both links for $62. Not bad in my book.
http://www.flickr.com/photos/62639173@N03/6603127177/http://www.flickr.com/photos/62639173@N03/6603127177/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Just waiting on the new spindle studs from Part's Mike.....
The joints are the 3 in the front axle.
Old Dec 30, 2011 | 05:23 PM
  #238
Edgethis's Avatar
Edgethis
Also got some good news from Thumper19, he found some E150 sag pumps and brackets, he plans to go get some next week and send me one! I can't wait!
Old Dec 30, 2011 | 06:25 PM
  #239
Jigger2020's Avatar
Jigger2020
Brett, is that the PS you're talkin about
Old Dec 30, 2011 | 06:46 PM
  #240
Edgethis's Avatar
Edgethis
Yes, after searching every shop and trying everything to find a bolt on pump adequate for our trucks, I finally gave up. Then I got to talking with Thumper19 on here and he offered to go check out his local junkyard. He found a couple in great shape so *fingers crossed* when he has a chance to go back next week, ill finally get my Saginaw power steering pump.
