1978 - 1996 Big Bronco
Operation: Zebra build
Old Nov 25, 2011 | 01:50 PM
  #106
Edgethis's Avatar
Edgethis
Thanks Gerry, I did check it all over for leaks, all good. I got scared when I jacked it up to remove the stands because all the sudden I had a puddle of fluid! It dripped out from under the front diff where it pooled. Sure gave me a start tho.
Old Nov 25, 2011 | 09:25 PM
  #107
Jigger2020's Avatar
Jigger2020
Right on Brett, feels good to get r done eh
Old Nov 26, 2011 | 01:41 AM
  #108
Edgethis's Avatar
Edgethis
Just got Moog Balljoints ordered from Rockauto. Got all four for $120 not a bad deal since normally I see then for about $50 a piece.
Old Nov 26, 2011 | 02:17 AM
  #109
SideWinder4.9l's Avatar
SideWinder4.9l
I love progress....You seen my thread on the bad fuel gauge Brett?
I wish we weren't all strung out across the states....
Our womenfolk would DUMP us....Which is A-Ok...The trucks don't bitch....
Old Nov 26, 2011 | 02:03 PM
  #110
Edgethis's Avatar
Edgethis
It is too bad we aren't closer. I haven't seen your fuel gauge thread yet, but i'll look for it.
Old Nov 26, 2011 | 07:59 PM
  #111
Encho's Avatar
Encho
The Southernmost Mod
Am i seeing a love story starting here? "Brokeback Broncos" hehehehehe...
Old Nov 26, 2011 | 09:40 PM
  #112
Edgethis's Avatar
Edgethis
Don't make us take a road trip down there Encho! You'll see the Zebra coming a mile away.
Old Nov 27, 2011 | 11:02 AM
  #113
njneer1's Avatar
njneer1
Originally Posted by ErrorS
You sure you're removing it correctly? If your slipshaft isn't stuck and you're sure you unbolted it (I've had many moments like that), you have to pry upwards between the shaft and the box. I usually use a wedge of some kind and hammer, it's a lot easier than using a prybar. My pickle fork pitman arm pulley works and I think I usually just use that. It needs a tapping or hammering instead of a steady pulling to get off.
Mine had never been removed and I didn't have any issue, I don't see how one could get stuck. Then again, my Bronco is backwards, when someone tells me it's going to be hard getting off, it usually comes off easy and when they tell me it should come off easy, it's usually a pain..
and man, my Redhead is nice.. don't spend too much on a replacement because you'll probably still eventually go Redhead anyways. With my Redhead + Saginaw, I have one finger steering like a Cadillac but steering that's probably tighter than your Mustang.
I hear you there....good advice.....wish I had listened....I am on my 3rd reman parts store box and it still sucks...the O'reilly reman gear never made it out of the driveway....was bleeding it and it made a loud pop.....like a shotgun...think it snapped a tooth off....returned it....now on my second Advance auto "lifetime" (means once) reman.....I like them for about a week.....then they get sloppy .....on the plus side.....I can change it out in under 45 minutes now...... How much did your readhead cost for the Bronco ?
Old Nov 27, 2011 | 11:31 AM
  #114
Edgethis's Avatar
Edgethis
Yeah I planned on a redhead box eventually. Ive heard they're pricey but worm wonders.
Old Nov 27, 2011 | 12:00 PM
  #115
Encho's Avatar
Encho
They aren't pricey, i got a quote and i must say i was impressed since the price was 1/4 vs. the stock one here in Venezuela.
Old Nov 27, 2011 | 12:18 PM
  #116
Edgethis's Avatar
Edgethis
I can't imagine trying to get parts in Venezuela. There's also a few guys in Australia too. Shipping must be a killer.
Old Nov 27, 2011 | 04:23 PM
  #117
BaronVonAutomatc's Avatar
BaronVonAutomatc
I've got a Redhead gear, iirc it was ~$200. Coupled with a Saginaw pump the steering is almost too easy. When (if) I ever swap on an aftermarket steering wheel it will be something with a smaller circumference.
Old Nov 27, 2011 | 06:14 PM
  #118
njneer1's Avatar
njneer1
I emailed them today for a quote........hoping for a package deal on the Bronco and Excursion......if not .....I'll be all over it for $200 on the Bronco for sure......my sh@t@y gear for Advance was $175.
Old Nov 27, 2011 | 06:25 PM
  #119
Edgethis's Avatar
Edgethis
Holy Crap! Mine was only about $85 after the core was taken off. Mine just kinda blew up on me, otherwise I'd have ordered a redhead, still will iff the price is good after the new year. Let us know what you get quoted, shouldn't be much different for me.
Old Nov 27, 2011 | 09:21 PM
  #120
ErrorS's Avatar
ErrorS
I think I paid $260 for mine, then returned the core for $75 but had to pay for return shipping.
