Thanks for the info. I was able to contact Chelsea and with the info you provide about the.truck was able to come up with a solution. Thanks again for the info.
Was wondering, where is the best place to go online for engine parts for this truck? I need to order ignition parts, points, condenser, etc.. if I was looking in the regular parts stores, like rock auto, which only shows parts up to a f500, should they be the same parts as long as engine is the same?
True...Guess in just used to having to go that route when I'm looking for parts for my internationals...usually I have to find the right part number online then go to the local store and ordering the parts
Why buy parts on the internet and pay shipping charges when local NAPA and indie auto parts stores sell the same parts.
Get yourself some 'Cornbinder' parts catalogs (try: faxonautolit.com), then type the part numbers into PartsVoice.com & rearcounter.com.
Registration is required for PartsVoice, not so with rearcounter. Searching for NOS parts is free on both sites.
1948 thru 1989 Ford truck parts catalogs are available on CD's from hipoparts.com
Here are samples of illustration and text pages from the 1973/79 Ford Heavy Truck Parts Catalog:
Thank you sir..any thoughts on where I could a wiring diagram for my truck? also, on the ignition wiring harness, I've got a wire hanging that pulses 12 volts on and off with the switch on, engine not running..any idea what it is?
Any thoughts on where I could get a wiring diagram for my truck?
Store located in Riverside CA .. Ed's not there on Saturday.
I know more about the Blue Ridge Parkway (it was closed north of Boone last time I was there) than I know about wiring, can look up the part numbers and that's about it.
My luck, local stor Ed, where I get parts (and a discount), only show up to an F500.. Can you give me coil, distributor, and related parts numbers(condenser, points, plugs, etc) till I can get a parts book..
My luck, local stor Ed, where I get parts (and a discount), sameas F500.. Can you give me coil, distributor, and related parts numbers(condenser, points, plugs, etc) till I can get a parts book..
How 'bout a 1997 F-800 VIN 1FTYF80C2VVA36955. Are any small parts available for the cab? Why is it so difficult to get parts for Ford trucks? No website I've visited so far supports an F-800 ):
U did it again. Spending my money. Ordered that CD of my truck glad you put that link up for those. Figure that is the best $27. I could spend.
Now I have that CD, Wiring Diagram, Spec book, 1987, 6.6 and 7.8 motor book. 1987 Shop and motor manuals Bod, Chassis and Electrical to look through also. Now If I could only read wiring digrams. These have to be in french as my redneck southern brain can't figure them out.
