OLD DECODES
replacement engine
Hi Bill, i have not been able to sell my truck and the band would really like to have use of it again so have decided to replace the engine. i have busted push rods for sure and may have too much damage to rebuild this one. so my question is where can i get a replacement? my VIN: C70EVS15579, also what other engine would be appropriate, and could i go with an automatic transmission without changing rearend. thank You.
MSRP: $173.63 / FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $
Discount price not listed, it should be about $114.60.
Give them a call (800-669-6012), ask if they still have FT engines available.
Ok Bill,,, here is the new addition to the fleet
F60362231
The drivers door was swapped out with one from an F100,,, to bad, cuz the pass. door has the customcab surround.
Thanks Bill!
p.s. in re. to driveshaft,,,was able to get the coupler shaft straightened, problem solved!
F60362231
Thanks Bill!
1956 Ford COE C600
Hello, Here is my vin-C60Z6H25626 (here is a link to the decoded vin--- http://www.vinwiz.com/1953-1960fordt...in=C60Z6H25626)
I am looking for a U-bolt strap kit for the rear transaxle. The guys I bought the truck off of disconnected the driveshaft and threw them away. I also need a gas pedal, and the connection from the carb to the oil bath air cleaner. Thank you very much!
Mid 1990 big truck parts
Bill,
New guy here (lurked for a long time) .... I have a 1995 F800 rollback. 5.9 Cummins, auto trans. You appear to be a main source of info, so ............
I cannot find any Ford parts folks that will even begin to look up even simple components - I am sure, because of the age. I know there must be some availability - not tool long ago I redid a 64 C1000 with the help of a Ford parts guy here in town. Managed to locate all kinds of stuff - rubber, filters, etc. He is gone, no joy with anybody even attempting to locate parts.
After pretty simple stuff for the F800 - original rubber floor mat, break pedal rubber pad, fuse block - simple stuff.
Any suggestions as to what dealer/parts guy will take the few extra minutes to at least try?
My vin: 1FDNF82C2SVA82440
Thanks for any ideas as to who I might try.
Billy C.
Billy C.
NumberDummy,
This one might throw you through a loop. I just bought what I know is a 1969 F-100. The VIN on the door is incorrect but the title also has that VIN. Its Production numbers would put it as a '67 f100 but the title states the '67 VIN and then states it as a 1969 (I will have to figure out what went wrong there). The frame VIN on the other hand... this is where it is a little confusing so I am just going to give you the frame VIN. I do believe this one to be correct, but the production number would put it in a void between '68 numbers and '69 numbers.
F10YKD83640
Good luck! Hope you can figure it out for me.
F10YKD83640
NumberDummy,
F10YKD83640
but the title states the '67 VIN and then states it as a 1969 (I will have to figure out what went wrong there).The frame VIN on the other hand... this is where it is a little confusing so I am just going to give you the frame VIN. I do believe this one to be correct, but the production number would put it in a void between '68 numbers and '69 numbers.
F10YKD83640
Y = 360 2V
K = Kansas City MO Assembly Plant.
D83640 = 1969.
1969 Serial Number Range: D82,001-G90,000.
1968 Serial Number Range: C00,001-D82,000.
1967 Serial Number Range: A00,001-B82,000.
