OLD DECODES
Oct 28, 2016 | 02:18 PM
Thanks for checking. Can you tell me where the 1" were used and where the 5/8" were used?
Oct 28, 2016 | 02:24 PM
Ford Parts Specialist
Quote:
Originally Posted by
Outlaw56
Your guess is as good as mine, since the parts catalog only says under the
22800-1 hinges:
The black star before
20327-S8 means this bolt was obsolete by the time this parts catalog was printed (1964).
Oct 28, 2016 | 03:35 PM
ok, thanks for the information.
Nov 3, 2016 | 09:03 AM
Can you tell me how to identify and locate a distributor vacuum advance diaphragm for a 1970 F-700 w/361 engine? The distributor is a governed type (Holley two barrel carburetor). The distributor
numbers are: C8TF 12102 074. Thanks.
Nov 4, 2016 | 01:05 PM
Tommy Tillman
The distributor is a governed type (Holley two barrel carburetor). The distributor ID engineering number is: C8TF 12102-?
You omitted the suffix, but there are only two possible, both use the same advance.
ID engineering number: C8TF-12102-A or C8TF-12102-B = COTF-12370-A .. Vacuum Advance (Motorcraft DD-13 ) / Obsolete
OBSOLETE RELIABLE PARTS in Nashville GA has
1 = 229-686-5101.
MCDONALD OBSOLETE PARTS in Rockport IN has
2 = 812-359-4965.
CARPENTER
NOS OBSOLETE PARTS in Concord NC has
3 = 800-476-9653 (listed as
C0 TF )
GREEN SALES CO. in Cincinnati OH has
22 = 800-543-4959.
If there's a NAPA and/or indie auto parts store in your area, you could give them the Motorcraft part number (can be crossed over to the brands they sell), to see if they can get you one.
Nov 6, 2016 | 09:10 AM
vacuum advance
Thanks for the info. I have one ordered from a local NAPA.
Dec 11, 2016 | 09:53 AM
Hi Bill.
Need your help finding a motorcraft distributor for my truck.
My truck is a 92 f150 302 manual 4wd.
The part numbers I found are theses F2TZ12127A. DA-2063 DA-2064.
Seems like Ford made one for a auto and manual transmission. The prices for each was way different, the manual being 3x higher in price for some reason.
I'll settle for a auto unit if tour able to find one.
Thanks in advance for your help.
Here's a pic of my vin if you need it.
Dec 11, 2016 | 02:31 PM
PRIMERED79 SHORT BED
Hi Bill. Need your help finding a motorcraft distributor for my truck.
F2TZ12127A (Motorcraft DA-2064 ).
Seems like Ford made one for a auto and manual transmission.*
Found two of the above, see my post your thread in the 1987/96 forum.
* There's no way to look up distributor individual applications after 1979.
The only way is by the trucks specific Calibration Code.
Motorcraft
DA-2063 is
F2TZ-12127-BA .. It's much more expensive than
DA-2064
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746. They also have F2TZ-12127-A
Dec 11, 2016 | 02:49 PM
Thanks Bill I will call on Monday.
Dec 18, 2016 | 09:25 AM
Bill
Wheel cylinders, brake parts
Kingpin rebuild kit
1969 ford f600 base model 6 cylinder four speed two speed
Vin f60brb16195
I believe it may be 15k gvw.. its definitely base model
Wheel cylinder MAY BE Citt-2161 (A) ??? but I cannot read it well
That may cross to dorman W36075 or Bendix 033716.. again not sure
https://autoplicity.com/311437-dorma...FU9tfgod2IIGFw
I need brake shoes.. parts kit.. wheel cylinders..brake hoses.. Kingpin kit...
Brakes are measured at 14 x 2 1/2
What says the master?
I have a line on a 79 front end ..if I cannot get the parts to rebuild this to new then I might consider the conversion if they are swappable.
Thank you Bill... as always... I have no manuals on this truck
Respectfully
Cam
Update ..Bill I found another post where you posted the brake diagram..Im on the right track.. so thansk
Now.. kingpin mystery
I found this from an old post of your too
However, from the looks of things (MAX DIA 14), you have 14" brakes...and luckily, there only ONE type.
The axle weight is either 5,500 or 6,000 lbs. front axle capacity.
Brake shoes are 14" x 2 1/2"
Front wheel cylinders are: 1 1/16" in diameter.
King Pins: 1964/72 F600 5500 or 6000 lb. axle capacity:
C3TZ-3111-A
FTE sponsor GREEN SALES has 10 sets of these king pins sets in stock: 800-543-4959 EST.
Apparently this company used to manufacture ford king pins.. havent talked to them yet
http://www.stemco.com/products/suspe...-and-bushings/
Dec 18, 2016 | 11:02 AM
To verify, please post the AXLE code stamped on the Warranty Plate.
Dec 19, 2016 | 12:51 PM
Hey Bill, my little town has an older ford fire truck that needs an S-cam Tube right rear. Let me know if you can find anything.
VIN
1FDYK84A0JVA01955
Thank you!
Dec 19, 2016 | 01:25 PM
psmith0803
VIN
1FDYK84A0JVA01955
What in the world is this?
Dec 19, 2016 | 02:14 PM
Are you questioning the part or the truck VIN?
I've double checked the VIN I'm sure it correct.
The part and maybe i'm using the wrong name for it. The truck has air brakes the S-cam goes thru this tube and the brake chamber attaches to it.
Dec 19, 2016 | 03:11 PM
psmith0803
Are you questioning the part ?
I have no idea what an S-cam tube is.
VIN decodes to a 1988 F800 diesel.
