Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Feb 18, 2017 | 12:05 PM
  #571
shillinghillf600's Avatar
shillinghillf600
Transmatic not listed for an N Series. The only way I can help you is if you list the diameter of the bearing.
Thanks, I'm gonna try to find a parts truck, I don't have the old bearing to go by.
Old Feb 18, 2017 | 06:07 PM
  #572
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Bill... I'm trying to find the part number to valve cover stud bolts on a 1999-2001 7.3L.
When I go to my illustration for 6582, I see neither bolts nor studs called out. In fact, when I look at the valve cover illustrations for ANY engine, I fail to find where the valve cover bolts are called out. This basically means that I'm operating way out of my depth as far as how to look up parts.
Improvising with whatever might be found at a hardware store is more difficult with valve cover stud bolts, because they are neither bolts, nor studs, but a combination of both, and are hard to find anywhere. I'm not even sure I'm using the correct descriptive word for an effective online search.
In the case of the 7.3L, there are two valve cover "stud bolts" that are used on the driver's side valve cover to attach bracket 6K854 (Section 67.1, Pg 3, Illus P-34338).
There are also two more stud bolts that are used on the passenger side valve cover to support the heater two hose clips 18 D 331 (Sec 184, Pg 28, Illus P-34520), but could also have something do with supporting whatever 30592-R1 combined with 9647 is, which was unclear to me (Sec 62, Pg 34, Illus P-37772). Again, none of these part numbers describe stud bolts themselves, which are not illustrated anywhere that I can find.
I don't know if the stud bolts between the left hand and right hand valve covers are the same, but I'd love the part number for both styles, if different. As of now, I can't find a part number for either side.
I'm looking to replace a few valve cover bolts with stud bolts to facilitate mounting an additional custom accessory bracket on the engine cleanly. Your help in locating a part number for the valve cover stud bolts would be greatly appreciated!
Application: 2000 F-550 7.3L
Thanks!
Old Feb 18, 2017 | 06:10 PM
  #573
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In the case of the 7.3L, there are two valve cover "stud bolts" are used on the driver's side valve cover to attach 6K854 (Section 67.1, Pg 3, Illus P-34338).
There are also two more stud bolts that are used on the passenger side valve cover to support the heater two hose clips 18D331 (Sec 184, Pg 28, Illus P-34520), but could also have something do with supporting whatever 30592-R1 combined with 9647 is, which was unclear to me (Sec 62, Pg 34, Illus P-37772). Again, none of these part numbers describe stud bolts themselves, which are not illustrated anywhere that I can find.
I'm looking to replace a few valve cover bolts with stud bolts to facilitate mounting an additional bracket on the engine cleanly. Your help in locating a part number would be greatly appreciated!
Thanks!
What parts catalog did you get there numbers from?
Old Feb 18, 2017 | 06:34 PM
  #574
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Bill, my illustrations are all dated 1999 and 2000. I see yours has a "FINAL ISSUE" dated in 1994, but in other posts and sig, you've mentioned that you have information up to and through 2001.
In your illustration above, I can see valve cover bolt 58617-S2, but that isn't a stud bolt... it just looks like a regular valve cover screw without any threaded extension above the head that would permit other things to also be attached at the same time on the same stud. Also, isn't the 7.3L in your illustration for the older IDI, instead of the turbocharged Powerstroke? I have the turbocharged Powerstroke (built November, 1999).
The specific answer to your question is FCS 7753-01-LD dated December 2000.
Old Feb 19, 2017 | 01:59 PM
  #575
NumberDummy
1990/2001 Ford Truck Parts Catalog is on microfiche, so I cannot post pics from it.
Old Feb 20, 2017 | 05:31 PM
  #576
johnmloughlin's Avatar
johnmloughlin
Can you please tell me what engine is in F80FU765663? Thank you!
Old Feb 20, 2017 | 06:29 PM
  #577
NumberDummy
F80 = F800 (gas).
F = 391 4V FT engine.
U = Louisville KY Assembly Plant.
765663 = 1966.
Old Feb 20, 2017 | 07:05 PM
  #578
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Oh I don't care about the pic, I just need the part number.
Old Feb 23, 2017 | 11:06 PM
  #579
BWheels's Avatar
BWheels
Help with a P35
Bill
Can you please decode this one and give me some standards? P35AL754434. The only tag is from Grumman Olsen. It has a freshly rebuilt and hopped up 240ci and what looks like a Dana 70 rear. It has a solid front axle that I'm hoping someone can tell me how to upgrade to disc brakes. It also has a 3 speed manual that's gear are so far apart it almost impossible to drive on the freeway. Looking to upgrade the trans to an auto with overdrive or manual with overdrive. Also looking to see what my options are for my manual steering gear box that's worn and sloppy. It has the long shaft that goes to the steering wheel making difficult to service.
Thanks so much!
Old Feb 24, 2017 | 11:06 AM
  #580
NumberDummy
Originally Posted by BWheels
Bill
Thanks so much!
Info and VIN decoded in your other thread in the 1961/66 forum.
Old Feb 25, 2017 | 10:58 AM
  #581
BWheels's Avatar
BWheels
Yes sir. Thanks!
Old Mar 3, 2017 | 06:08 PM
  #582
telescope-tech's Avatar
telescope-tech
2000 F650 transmission ID
3FDWF65HXYMA15135
TR=K
Someone near me is parting this truck and I was wondering which motor and transmission were fitted.
I'm pretty sure it's a CAT 3112 motor but no clue about transmission.
Old Mar 3, 2017 | 07:53 PM
  #583
NumberDummy
Originally Posted by telescope-tech
3FDWF65HXYMA15135
TR=K
Y = This is a 2000, but I cannot access my parts catalog at this time.
H is the engine code, call a dealer and ask them what it is.
Old Mar 3, 2017 | 09:06 PM
  #584
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
It can't be a CAT 3112 motor, because Ford never installed a CAT 3112 motor in any vehicle in any market in any year. I don't even think CAT has ever made a 2 cylinder engine to power an on road highway vehicle. The last digit in CAT motor numerology designates the number of cylinders. In short, the 3112 doesn't exist.
However, letter code H designates a CAT 3126B motor, which is a 7.2L inline 6 cylinder engine (hence, the "6" as the 4th digit of the motor model number). Ford installed plenty of CAT 3126B motors in F-650s, which is what the F65 means in your VIN... more specifically a two wheel drive regular cab.
The 3126B motor was available in the F-650/750 in five different ratings, ranging from 190HP/520TQ, up to 250HP/600TQ.
As a general rule, the F-650/750 class of medium duty trucks are far more customizable as far as drivetrain is concerned than the lighter duty trucks. Therefore, there are many transmission options available... five different manual transmissions, and six different automatic transmissions.
Based on the W in your vin, I'm assuming the truck has air brakes, but is still under 26,000 lbs GVWR (Class 6 designation). Therefore, of the 11 transmissions available, a couple of those transmission options were limited to the F-750 (Vin Code X) at 33,000 lbs GVWR. Still, it would be help others help you if you at least identified if the truck is automatic or manual. If manual, is it a 5 speed, 6 speed, or 7 speed? If automatic, is it a 4 speed, 5 speed, or 6 speed?
Old Mar 5, 2017 | 10:35 AM
  #585
shillinghillf600
Reflector
Hello All, I'm looking for the amber reflectors mounted on the lower front corners of the hood of my 69 N850. The number on the lens is SAE-A67-ATK, I saw D.C. Has a repop amber reflector C8TZ-13380-C, Will this work? I have the original ones that were on the truck but they are damaged and would like to replace them.
Thanks for any input Bill
