It is a small switch with three lines going to it and I think the thing has a couple wires to it also but is broken I am thinking. I only have computer at the library so don't get here everyday. Any help will be appreciated.
Where on the engine is this vacuum switch located? Take a close look at it, it may have an ID engineering number marked on it (might be D32E-A).
NumberDummy... You seem to be the man, so I sure hope you can help.
My brother & I 'thought' we were all set to do the rear brakes on my 65 F100, but we didn't get too far, as she appears to be missing some essential parts. I found old part numbers, but do not have knowledge to figure out what other vehicles used same parts.
VIN: F10JL607547
Welcome to FTE
Brakes need:
Lever Parking Brake Operating = Same as 1964/67 F100 2WD; 1966/75 Bronco with 11" x 1 3/4" brakes; 1963/66 Thunderbird.
C3SZ 2A637-A RH
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
--------------------------------------------------------------------------- C3SZ 2A638-A LH
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
KAMA OBSOLETE PARTS has 2.
Link-Parking Brake Operating Lever to Brake Primary Shoe = Same as 1964 F100 2WD from serial number 470,001; 1965/67 F100 2WD; 1966/67 Bronco with 11" x 1 3/4" brakes. Notice corrected part number:
C4TZ 2A642-B x2
CARPENTER NOS OBSOLETE PARTS has 1.
CROSSETT FORD in Crossett AR has 1 = 870-364-2162.
Spring Parking Brake Link
C4UZ 2A601-A x2
CARPENTER NOS OBSOLETE PARTS has 3.
NOS PARTS LTD has 7.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 607-722-5371.
KLIMESH MOTOR SALES in Calmar IA has 20 = 563-562-3241.
Please ask further questions in the 1961/66 F100 and larger truck forum. This is the LARGE TRUCK forum for 500 and larger series trucks.
Thanks NumberDummy, just realized my post was in wrong forum, but I did just repost it in the correct forum. Would you mind posting your reply there too for others to find in the future?
Thanks again!
Im looking for new old stock door hinge bolts for 56 F series trucks, any source?
You should ask questions in the 1948/56 F100 and larger truck forum. This is the LARGE TRUCK forum for 500 and larger series trucks.
1953/56 Trucks:
12) 20387-S8 .. Bolt-hex head - 5/16" -24 x 1.00" long / Obsolete
No Ford dealer or obsolete parts vendor has any.
12) 20327-S8 .. Bolt-hex head - 5/16" -24 x 5/8" long / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2,252 = 800-476-9653.
24) 34806-S7 .. 5/16" Spring type Lockwasher / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 184 = 701-523-3257.
GREEN SALES CO. in Cincinnati OH has 324 = 800-543-4959.
