Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Jul 6, 2016 | 11:57 AM
  #466
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Not to mention that the screwed in VIN plate says the Color is RED, while the truck itself doesn't appear to have any old traces of red in the door jamb or under the layers of chipped paint. Does the truck still have the two speed rear end?
Old Jul 6, 2016 | 12:41 PM
  #467
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hawkdog
This might work better... if it works.
F60 = F600.
U = 272 4V Heavy Duty.
7 = 1957.
16352 = 1957 Numerical Sequence of Assembly, the trucks specific serial number.
17,000 lbs. Gross Vehicle Weight Rating.
172" Wheelbase.
149 net HP @ 3,600 RPM
New Process model 540-FD11 5 Speed Direct Manual Transmission.
Eaton model 13200 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
F = Starmist (Light) Blue (Red is COLOR code R).
4C7 = Assembled March (C) 4, 1957 (7).
Old Jul 6, 2016 | 01:17 PM
  #468
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Thanks for the clarification on the color Bill.
Curious, what does "RED" mean?
Old Jul 6, 2016 | 02:06 PM
  #469
NumberDummy
It means someone stamped the wrong color on the plate.
Look up the date, see if the truck was assembled on a Monday or Friday.
Old Jul 6, 2016 | 07:34 PM
  #470
Az75F150's Avatar
Az75F150
Hello,
I would appreciate whatever you can tell me about this truck that I recently bought: F15JKW01271
Thanks,
Scott
Old Jul 7, 2016 | 09:54 AM
  #471
NumberDummy
F15JKW01271
F15 = F150 2WD Pickup / J = 460 4V / K = Kansas City MO Assembly Plant / W01271 = 1975.
This is the LARGE TRUCK forum, for 500 series and larger trucks.
Since your truck is a 1975 F150, please ask further questions in the 1973/79 F100 and larger truck forum.
Old Jul 7, 2016 | 10:29 AM
  #472
Az75F150's Avatar
Az75F150
Thanks, I really appreciate the info. Got it; I searched on build data and ended up here and did not even notice which forum I was in..
Old Jul 7, 2016 | 10:36 AM
  #473
NumberDummy
You can get a copy of your trucks original build sheet from martiauto.com
Marti is located in El Mirage, NW of Phoenix, west of the Black Canyon Freeway.
Old Jul 7, 2016 | 10:46 AM
  #474
Az75F150's Avatar
Az75F150
Thanks yet again!
Old Aug 8, 2016 | 09:05 PM
  #475
tei-fab's Avatar
tei-fab
exhaust part numbers
any help with trying to find exhuast parts/numbers for manifolds back on my n600 with a 361 would be awesome !
Old Aug 8, 2016 | 11:24 PM
  #476
Stretchmobile's Avatar
Stretchmobile
Numbers, I have a somewhat difficult question. I bought the front end out of a 93 F700 cheap with the same 6 bolt pattern. The axle is too wide to just put under my 67 F600. The caliper mounting brackets do bolt on to the spindle. The spindle stub on the 700 is longer and larger than my 600 and the hub won't fit. Question: is there an earlier F600 that has disc brakes that has the same spindle dimensions or close to my F600?
Old Aug 9, 2016 | 02:41 PM
  #477
NumberDummy
Originally Posted by tei-fab
Any help with trying to find exhaust parts/numbers for manifolds back on my N600 with a 361 would be awesome!
C4TZ-9430-B .. Right & Left 330/361/391 Rams Horn Exhaust Manifolds / Obsolete
1964/78 all 500/800 series trucks.
No Ford dealer or obsolete parts vendor has any.
C3TZ-5230-B .. Muffler / Obsolete
1964/67 N500/750 330/361/391.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
MCDONALD OBSOLETE PARTS in Rockport IN has 2 = 812-359-4965.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 6 = 800-476-9653.
C4TZ-5246-A .. Right Inlet Pipe / Obsolete
1964/66 N500/750 330/361/391.
C4TZ-5267-A .. Left Inlet Pipe / Obsolete
1964/66 N500/600 330/361/391.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
C2TZ-5255-E .. Outlet Pipe / Obsolete
1964/69 N500/750 330/361/391.
NOS PARTS SOURCE has 1.
CARPENTER NOS OBSOLETE PARTS has 1.
BOWMAN SALES & SERVICE has 2.
GREEN SALES CO. has 6.
Old Aug 9, 2016 | 05:48 PM
  #478
tei-fab's Avatar
tei-fab
thanks for the information again bill !
Old Aug 10, 2016 | 11:50 AM
  #479
Jack the Knife's Avatar
Jack the Knife
C700 - a problem title
What is the best way to confirm the year of a c700? I have the original bill of sale, and know it is a 1967. The problem is I have a PA title from 1995 that in fact does not state the year of the vehicle. Just the warranty number and the GVWR. For some reason the good people at PennDot left that out.
When trying to apply for a title in Maryland, MVA said I need to get a corrected title from PA. Holy government run around. Maryland did seem amenable to some other kind of proof of year, so I was planning on trying again with the bill of sale, and any other information I can glean from the 11 digit warranty number that consul sly demonstrates that it's a 1967. I plan to get the 1967 shop manuals, and see what I can get from the production number series. But what I'm starting to think is even better would be the parts catalog.
Thoughts?
Below is my door tag.
Old Aug 10, 2016 | 12:18 PM
  #480
NumberDummy
Originally Posted by Jack the Knife
What is the best way to confirm the year of a C700? I have the original bill of sale, and know it is a 1967. The problem is I have a PA title from 1995 that in fact does not state the year of the vehicle. Just the warranty number and the GVWR. For some reason the good people at PennDot left that out.
C70 = C700 Tilt Cab.
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
A72775 = 1967, assembled January 1967.
1967 serial number range (except E100): A00,001-B82,000.
