Mr. NumberDummy Can you help me locate some parts for my 1978 F-250 4X4 ?
I suggest you open a new thread in the '78 forum further down the page. This is large truck, not F250. Also, specify what you are looking for, and if you like list your VIN and the warranty plate info.
Thank you for the generous offer of sniffing out parts, no good deed goes unpunished! Door plate:F66FVCE 0734 158 K F661 GA8 M 55J 24000 558019. front axle: rockwell FDS 75 HDX 89 D5HS-3002-RA 974130 HY11478 0720
wish list:
1) right front axle stub shaft, 30 spline
a/r) all seals for complete right front axle shaft assy.
assortment)king pin adj. shims (full brg. design)
2)wheel brg. nut locking washers (bend tab type)
everything) o.e.m. dash mount tachometer
manuals, paper or plastic? paper if possible!: owner, service,parts
email: detroitdieselwilliams@gmail.com
thank you
Please pardon my computer illiteracy, I am new to this forum stuff
wish list:
thank you
Pardon my computer illiteracy I am new to this forum stuff
I recently purchased this 1997 F-800 thru an auction.
The door plate is as follows:
Date:07/96 9727A
GVWR: 2600 LB / 11793 KG
VIN: 1FDNF80C4VVA19590
Tire F/R: 10RX22.5F / 10RX22.5F
RIMS F?R: 22.5X7.5 / 22.5X7.5
PSI (KPA) Cold Frnt: 100 (689) Rear: 100 (689)
EXT Paint: BW DIST: 53 DSO:Blank
WB: 225 Type_GVW F80260 Body: 8 Trans: DE Axle: JC
ON FGAWR 7000LB RGAWR 19000LB
I was told by the nearest Ford Truck dealership that this F-800 had a Eaton-Fuller 5 spd and Rockwell 2 spd rear end.
In driving it home I discovered the following:
1) Speedometer was registering 75 mph in 5th gear and high side, with my foot on the floorboard, but my garmin and my son following in his car verified that I was only doing 55 mph on the down hills. This made a long trip without cruise control...Foot to the floor and my hand on my knee to keep the pedal to the floor.
2) PTO was removed by a previous owner but all of the other equipment is present to raise the 14 ft flatbed.
I need to do something to reduce the rpm's on the 5.9L Cummins to get around 1800 - 1900 rpm's so I'm needing help deciding the route to take either replacing the rear jug or transmission.
I am also finding out that Chelsea no longer offers a manual PTO for the Eaton-Fuller FS-5205A with an external PTO pump which this truck has. I know one can be built but I need to decide if I'm going to replace the tranny before I take that step.
Any and all suggestions will be greatly appreciated.
hugger94
A couple of months ago I bought a 1990 F800 that came with a parts truck (1988), but it took them a while to get the parts truck to me, so I waited until I had both to ask for help decoding the VINs.
At the present time, I cannot decode anything newer than 1989, as microfiche viewer bulb burned out. New bulb on the way, as "She who must be obeyed" ordered it online.
I understand.... and I can wait. Thanks, NumberDummy.
I need a fuel sending unit for an 89 f250 7.3 idi diesel. This is for the rear tank behind the axle. My fuel gauge doesn't work and it's because the sensors are bad on the sending unit. I can't find one anywhere. I am in the Columbus, Ohio area
I need a fuel sending unit for an 89 f250 7.3 idi diesel. This is for the rear tank behind the axle. My fuel gauge doesn't work and it's because the sensors are bad on the sending unit. I can't find one anywhere. I am in the Columbus, Ohio area.
This is the LARGE TRUCK forum (F500 and etc), ask your question in the 1987/96 forum, or the Parts Wanted forum.
Incomplete Vehicle Manufactured by Ford Motor Co
Date 3/97 GVWR : 25900
yada yada normal tire and VIN stuff
Then
EXT Paint: RC: 87 DSO:
WB TYPE-GVW BODY TRANS AXLE
255 F70259 8
Truck is Yellow and if it was painted, it was Painted Yellow Everywhere which is confusing with the WB code as I assume that means a White of some sort.
I'm talking , factory type yellow door jams, inner door panels , ect ect.
Door ID tags rivited over the yellow.
My thinking is that the truck was a contract vehicle or CPO for maybe Penske.
Either way , Transmission info ? Axle ?
The info above is all there is.
