Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Sep 14, 2015 | 05:48 PM
  #346
85e150's Avatar
85e150
Originally Posted by Kevin1966f600
Is It impossible to run a pto and a automatic transmission , i thought that the ford C6 automatic transmission was about the toughest automatic transmission they made in the 60s, 70s and 80s
The C6 is tough in cars. In medium trucks, it is marginal.
391 HP/TQ. Still pathetic, but better than the 330. Post 7 has some HP/TQ ratings:
https://www.ford-trucks.com/forums/9...361-391-a.html
It is NOT possible to run a PTO off a C6. There is no provision for a PTO port on that transmission. Allison automatics can be equipped with a PTO. Not sure about any other auto trans.
An F250 runs about 6000 lbs probably, maxing out somewhere below 10k. The F600 starts about 10,000 for a cab and chassis, and the GVWR for yours is 20,000.
Later F600s with the 370/429 would be a source for mounts and possibly other parts to aid the swap. The Lima 429 differs from the car 429 enough to make engine parts non-interchangable, so accessory drives, if any, have to be brought over.
Your '70 429 is going to be in the 11s for compression. High loads and high compression for long periods is not advisable.
Good luck with it.
Old Sep 14, 2015 | 07:25 PM
  #347
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bluesdefender
Bill: THANKS A MILLION! They're on the way. The fella at Green Sales (800) 543-4959, also said I could fax or email them a list of PNs and they will bounce it off their inventory; what a great resource you are. G
I found the boot on PartsVoice.com and rearcounter.com .. not on greensalescompany.com .. Green also has their inventory on these two websites.
These two websites list dozens of obsolete parts vendors. PartsVoice also lists 100's of FoMoCo dealers. You have to register on PartsVoice, it's free. rearcounter, just sign on and type away.
Type the part numbers without any spaces or hyphens, like this: B9C7277A
Northwoods WI .. Would this be Door County by any chance?
Old Sep 14, 2015 | 09:22 PM
  #348
jgoodman6891's Avatar
jgoodman6891
Tie rod ends & tube.
Bill can you get me the part numbers please. Local parts house is having hell finding them for me.
Thread on my truck
Front axle code - HHX: X = Ford 7,000 lbs. Capacity Front Axle with P/S
Old Sep 15, 2015 | 01:09 AM
  #349
NumberDummy
Thread on my truck
D6TA-2011-MA = Wagner 15 x 4 cam front air brakes.
3280 tie rod assy. replaced by individual parts (see pic below).
D5TZ-3A130-A .. Right Tie Rod End / Obsolete
WILBUR FORD SALES in West Union IA has 1 = 563-422-3881.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
D5TZ-3A131-A .. Left Tie Rod End / Obsolete
WILBUR FORD SALES has 1.
GREEN SALES CO. has 7.
D5TZ-3281-A .. Spindle Connecting Rod Tube / Obsolete
RED TAYLOR FORD in Corning AR has 1 = 870-857-3518.
GREEN SALES CO. has 13.
Old Sep 15, 2015 | 08:56 PM
  #350
jgoodman6891
Thanks again Bill!!
Old Sep 23, 2015 | 01:04 AM
  #351
redtrek's Avatar
redtrek
7th Gear
Frankenstein Front Spindle
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Hi Bill,
You've been able to answer some pretty tough ones. I hope this is simple. The short version is this: is the 706528 spindle interchangeable with 706528x?
The long version is this: My 1970 F100 Ranger started life as a 2WD 3 or 4-speed, likely with a 390FE. When I got it, somebody had changed out, well, pretty much everything except the body: built 302, C4 with a B&M kit, Dana-Spicer 24 1-ton transfer case, Dana 44 front axle and GM disc brake conversion (among a host of other mods). I recently needed to replace the bearings and decided new rotors & pads would be a good idea. A friend helped and we got it all swapped out, but within about 15 miles of driving, things got weird and I found that the front right spindle had sheared off near the mounting flange. Because none of this front drive train is original, I'm open to any input on what to do. I'm fairly certain the spindle I took off is part #706528, based on the journal measurements. I can provide a picture of the broken one, if that would help.
Old Sep 23, 2015 | 06:12 AM
  #352
NumberDummy
Originally Posted by redtrek
Hi Bill,
Basic Ford part number for a spindle is 3105, I have no idea what number 706528 refers to.
This thread belongs in the 1967/72 F100 and etc forum where members own like trucks. This is the LARGE TRUCK forum, for 500 and larger series trucks.
Old Sep 23, 2015 | 12:44 PM
  #353
redtrek's Avatar
redtrek
7th Gear
Okay, thanks! Sorry about that. This truck has been fun, but also a pain. It's probably a GM part.
Old Sep 24, 2015 | 09:42 AM
  #354
krewat's Avatar
krewat
FTE Leadership Emeritus
It is, took about 2 seconds to find with Google:
GM Chevy Small Bearing Disc Brake Spindle 706528 Dana 44 w Seal Kit Axle Bearing | eBay
Old Oct 3, 2015 | 08:57 PM
  #355
diharris's Avatar
diharris
Want to know what I just bought. Thanks.
N70DUA61558
163 C N700 E81 A G2B
22000 164 3800 530177
Old Oct 4, 2015 | 05:21 AM
  #356
NumberDummy
N70DUA61558
Based on the last 6 digits of the VIN, this could be a 1967 N700 or a 1976 LN700.
Column right, 2nd entry: N/NT Series / Column right, 3rd entry: LN/LNT series.
Pick the correct truck, I'll decode the info accordingly.
Old Oct 4, 2015 | 08:13 AM
  #357
diharris's Avatar
diharris
1967 N700, right column, second entry
Old Oct 4, 2015 | 12:06 PM
  #358
NumberDummy
VIN: N70DUA61558 / Warranty Plate: WB: 163 / COLOR: C / MODEL: N700 / BODY: E81 / TRANS: A / AXLE: G2B / MAX GVW LBS: 22000 / CERT NET HP: 164 / RPM: 3800: DSO: 530177
N70 = N700 (gas).
D = 330 2V Heavy Duty FE Engine.
U = Louisville KY Assembly Plant.
A61558 = 1967, assembled December 1966.
163" Wheelbase.
C = Pure White.
N700 (gas), 22,000 lbs. GVWR
E81: E = Red Petticrush Vinyl & Red Leeds Pattern Woven Plastic // 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
G2B:
G2 = Eaton model 16802 Two Speed Rear Axle / 5.57/7.75 / 17,500 lbs. Rear Axle Capacity.
B = Ford 5,500 lbs. Capacity Front Axle.
22,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
530177:
53 = Kansas City MO Ford District Sales Office, where the original selling dealer ordered the truck from.
0177 = Domestic Special Order number. Truck special ordered by the original purchaser, not "bought off the lot.."
Old Oct 11, 2015 | 02:31 PM
  #359
jfgold's Avatar
jfgold
Need some specs, Bill Please help...
Just bought a 1982 Ford F700 Fire pumper from the government it is a 4 x 4 conversion. VIN is 1FDMF70H2CVA19778 Body Code DT6, Trans AA Axle 55M. Thanks in advance for the help!
Old Oct 11, 2015 | 03:02 PM
  #360
NumberDummy
VIN: 1FDMF70H2CVA19778
PAINT: Omitted / DSO: Omitted
WB: Omitted / Type/GVW: Omitted / Body: DT6 / Trans: AA / Axle: 55M.
IFD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
M = Class 5 - Hydraulic Brakes - 16,001-19,000 lbs. Gross Vehicle Weight Rating.
F70 = F700 (gas).
H = 370 2V or 4V (6.1L).
2 = Check digit, FoMoCo use only.
C = 1982.
V = Kentucky Truck AssemblY Plant.
A19778 = 1982 Numerical Sequence of Assembly, the trucks specific serial number.
DT6: DT = Black H/D Vinyl with Nutmeg Appointments / 6 = No 6 listed.
AA = Allison model AT-545 Automatic.
55M:
55 = Rockwell (Timken) model H-172 Single Speed Rear Axle / 7.17-1 / 17,500 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with P/S
Parts catalog doesn't list the curb weight, as the "back of cab" equipment was installed after the truck left the assembly line.
