Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Mar 2, 2015 | 01:40 PM
  #271
meyers_3521's Avatar
meyers_3521
A big THANK YOU!
Old Mar 7, 2015 | 12:19 PM
  #272
allis327's Avatar
allis327
On my C750 if that is what is I found a plate hanging from the seat spring on the pass side.
VD2KB6064700AA
LSI - 2844
The V in the first seq is more of a upside down triangle.
The warranty plate in the pic is from a donor truck I am trying to buy. The junk yard guy didn't want to sell it to me at first but now after some ran into the cab with a loader things may have changed.
Old Mar 10, 2015 | 01:52 PM
  #273
72FordDump's Avatar
72FordDump
I am trying to get this trim tag decoded and to find a good place to purchase parts for this truck. I am presently in need of parking brake parts.
Old Mar 10, 2015 | 03:45 PM
  #274
PNWsail's Avatar
PNWsail
Question Numbers Help Please!
I am including all the numbers I found on the door jam (*'s replacing last digits of the VIN for my privacy sake) My primary interest is in the Trans and Axle codes.
Thanks in advance!!
Eric
VIN 1FDNF806VVA*****
Date 5/96 3178A
GVWR 24,500
EXT Paint: BW
DIST: 87
DSO: (Blank)
WB 177
Type -GVW F80245
Body 8
Trans DE (Which is this one???)
Axle A2 (Again, which one?)
On/Off
FGAWR 7000
RGAWR 17,500
Old Mar 22, 2015 | 07:48 PM
  #275
jacobsjo87's Avatar
jacobsjo87
Looking for a little help. I'm in need of a drum brake backing plate for my 1979 Bronco. I contacted all of the wrecking yards around here and can't find one. Mine seems to be the more rare one with the 3/8'' T-bolts.
Part number I have is:
Bendix 3205809-L
Is there a ford part number associated with this? I cant find one on the plate.
Edit: Found the for part number D8TZ-2212-A which should be drivers side. Is that right?
I haven't been able to locate one.
Old Apr 4, 2015 | 08:23 PM
  #276
Pete Kildow's Avatar
Pete Kildow
Bendix 3205809-L
Take a look at the same year half ton pickups. It may be the same, I know some parts cross over to these.
Old Apr 12, 2015 | 06:55 PM
  #277
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I contacted all of the wrecking yards around here and can't find one. Mine seems to be the more rare one with the 3/8'' T-bolts.*
Ford part number D8TZ-2212-A which is the left (drivers) side.
Applications: 1978/79 E100/150 / 1978/79 F100/150 2WD / 1978 F150 4WD from serial number BJ0,001 & 1979 F150 4WD / 1978 Bronco from production date 3/1/1978 & 1979 Bronco.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653. This is the only one I could find.
* 1979: 1/2" or 3/8" backing plate bolts mainly have to do with the 9" axle shafts. You need to know which size to get the correct shafts.
But...Bronco's & E100/150's have specific right & left axle shafts, while F100/150 right & left axle shafts are the same.
There is more than one axle shaft for all these vehicles as some have 28 splines while others have 31 splines. 1974/79: There are also two different types of rear axle bearings and seals.
Note: This is the 2nd time you've asked a question in this LARGE TRUCK (500 and larger series trucks) forum. You should ask questions...
There is a forum for 1978/96 BIG Bronco, another for EB's (Early Bronco's - 1966/77) and another for 1984/90 Bronco II's.
I asked a customer once if he had a full sized Bronco or a Bronco II. He said "FULL SIZED, I don't have a training Bronco!"
Old Apr 15, 2015 | 03:54 PM
  #278
351bolt's Avatar
351bolt
1977 F700 VIN Decode
Just picked up a new to me 1977 F700 and don't know a lot about it. Previous owner didn't know much about it either. Hoping to get the VIN and Data Plate decoded. Thanks
VIN F70FVY91779
Door Data Plate 212 M6 F703 DA8 2 E2H
74
Thanks
Pete
Old Apr 16, 2015 | 01:05 AM
  #279
Shade Tree Mech's Avatar
Shade Tree Mech
1976 LN 700 wiring
Bill,
I have a 1976 LN 700, I am working on a wiring problem. I have the Ford books but no wiring diagrams. I am working on lights/turn signals/brakes. Do you in your arsenal of FORD manuals have any wiring schematics for my truck?
Thanks for any help you can provide..
S.T.M.
Old Apr 16, 2015 | 11:09 AM
  #280
NumberDummy
Sorry, I have no wiring diagrams.
Old Apr 17, 2015 | 05:29 AM
  #281
Shade Tree Mech
Ok, Bill thanks, you know anyone on this site who might? Or where I can go to get one?
Shade Tree Mech
Old Apr 17, 2015 | 11:54 AM
  #282
NumberDummy
Dunno of any member who has wiring diagrams for a '76 LN700, but faxonautolit.com (store located in Riverside CA) might.
Old Apr 17, 2015 | 07:49 PM
  #283
Waysize's Avatar
Waysize
F750 Dum Truck vin F75EVQ74081 . Found a sticker that said the engine was a 361 EFW. Any indo would be helpful. Thanks, Waysize
Old Apr 17, 2015 | 09:51 PM
  #284
NumberDummy
Originally Posted by Waysize
F750 Dum Truck vin F75EVQ74081. Found a sticker that said the engine was a 361 EFW
F75 = F750 (gas).
E = 361 2V FT engine.
V = Kentucky Truck Assembly Plant.
Q74081 = 1973.
I have no idea what EFW refers to as I've never seen or heard of any such thing, and...
This abbreviation is not listed in the truck parts catalog.
Old Apr 19, 2015 | 05:35 AM
  #285
Shade Tree Mech
Bill;
Yes they did and I have one coming to me. Thanks..
Next question; I pulled the steering wheel and found my main problem, when the steering wheel was installed (some time in her past) they pinched some wires and now have been ground through. Duh, not wireless back then so it don't work.
I need a turn signal assey, horn ring and the steering wheel horn button if they are available.
Again Bill, we always appreciate all your time you spend on us crazy mech and our old money pits.. lol
S T M
VIN is N70EVB12528
