I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Hi I have a1967 f 100 with a 6cy . I bought It used and not running I think It has the wrong flywheel the number on it is C7TE-A . Can tell me if this is correct or what the correct one is. thanks
Hi I have a 1967 F100 with a 6 cyl. I bought it used and not running.
It has the wrong flywheel, the number on it is C7TE-A
This is the Large Truck forum, please type further questions in the 1967/72 F100 and etc. forum.
C6TZ-6375-C . M/T Flywheel-164T / Marked: C7TE-A / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1966/68 Bronco 289 / 1969/79 F100 & Bronco 302 / 1975/79 F150 302.
Does your 1967 have a 10" or 11" clutch? The I-6 flywheel is specific to each.
I just attempted to decode your VIN - See your other thread in the correct (1980/86) forum. This is the Large Truck (500 and larger series trucks) forum.
I have a wiper switch that does not work,,taken it apart several,,looks simple enough but still no electricity tru the switch,,,any exploded diagrams out there?,, or anyone have a good one for sale?,,thanks,,the ole fart Jimmy
I am in need of a wiper switch for my 63 f100, jimmy
