EZ Down tailgate assist
Old May 22, 2011 | 12:28 PM
  #226
2horses's Avatar
2horses
I bought two yesterday at my local O'Reilly's, on was the 01 for the older trucks and the other was the 02 for my 2011. Both were the old versions for 19.99. The only difference between the two is the mounting bracket
for the tailgate itself. I did have to modify the rubber bumper on mine, and the instructions did not say to remove it - but the instructions for the 01 did. Thanks to this thread I knew what to look for, and a little judicious use of a hacksaw resulted in this:
Works great! Good news is my boyfriend's truck is a '97, and the other one fit his just fine. So now we have matching tailgate assists!
Old May 22, 2011 | 03:45 PM
  #227
frt2599's Avatar
frt2599
Originally Posted by buckmasters
Mine was $19 also (reg price was $59). That squeak wasn't there before, but it isn't coming from the new hardware either. Must have something to do with coming down so slowly.
Anyone figure out what that squeak is? Mine is doing it now and doesn't seem to be coming from the ezdown hardware. Thought someone would know before I start spraying WD everywhere.
Old May 22, 2011 | 04:09 PM
  #228
capt caper's Avatar
capt caper
Isn't there a torsion spring inside the gate? I'd go ahead and spray selectively to you find out for me were it's coming from then grease it .
This thread just keep getting better. I can't wait for my new one coming this week. I just have to choose a way to alter the bracket to fit. Again I ordered one for an 2006.
jim
Old May 22, 2011 | 04:22 PM
  #229
Sgt93's Avatar
Sgt93
7600+ views
Old May 22, 2011 | 04:23 PM
  #230
2horses's Avatar
2horses
We had the squeak on my 2011, a shot of WD40 on the passenger side tg hinge took care of it temporarily. Probably should lightly grease the inside of the rubber sleeve for a permanent fix.
Old May 22, 2011 | 04:24 PM
  #231
frt2599's Avatar
frt2599
jim
OK found it. Right side hinge, just a little grease and squeak gone.
Old May 22, 2011 | 10:27 PM
  #232
kereams's Avatar
kereams
My new style broke today. The bolt that threads into the insert that was installed into the tailgate sheared off. Going to call DeeZee tomorrow.
Old May 23, 2011 | 08:13 PM
  #233
kereams's Avatar
kereams
Here's what broke on mine....
Old May 23, 2011 | 08:23 PM
  #234
buckmasters's Avatar
buckmasters
I got rid of the squeak tonight. Just a couple shots of white lithium did the trick (should last longer than WD40).
Old May 23, 2011 | 08:45 PM
  #235
lexustbs's Avatar
lexustbs
Originally Posted by Sgt93
7600+ views
I want this thread to die on the second page so bad! UHHHH!
Old May 23, 2011 | 08:53 PM
  #236
dschuffert's Avatar
dschuffert
For some strange reason, this thread will keep going, and going, and going............
Old May 23, 2011 | 09:02 PM
  #237
houstonmr's Avatar
houstonmr
Just to clrarify, this one is the "new" style with the smaller shock and the ball-type mount. The "older" style has a bigger diameter shock, no rubber ring at the end and it uses a clip to secure the shock to the tailgate mounted bracket. You can see this in the picture a few posts above.
Old May 24, 2011 | 07:32 PM
  #238
catfish150's Avatar
catfish150
Howdy Folks, new guy here. been lurking for awhile. I purchased and installed mine this evening. $20 at O'Riellys. Works like a charm.
YouTube - ‪2011 F350 EZ-Down Tailgate Assist‬‏
Old May 24, 2011 | 07:52 PM
  #239
Rutcutter's Avatar
Rutcutter
I see you didn't have to trim the rubber bumper for it to fit.
Old May 24, 2011 | 08:04 PM
  #240
Sgt93's Avatar
Sgt93
Over 8000 views
