EZ Down tailgate assist
Old Apr 25, 2011 | 08:06 PM
  #136
Part-Timer's Avatar
Part-Timer
I just got the one I ordered from Amazon about 10 days ago. I was expecting it to be the newer style because Amazon only got them back in stock recently. I was pleasantly surprised to find that it was the old style unit that doesn't require me to remove the bumper and also slows the tailgate down more.
Brian
Old Apr 26, 2011 | 08:02 AM
  #137
TexasA&M's Avatar
TexasA&M
I've been following this thread and am thinking of ordering one of these for my 2006. Does anyone know if ALL of the cylinders are fubar'd, or is it only the models for the 2011 trucks? I wish I could find one local to look at, but I will most likely have to order it online. $40 is about the cheapest I can find (including shipping).
Old Apr 26, 2011 | 09:27 AM
  #138
houstonmr's Avatar
houstonmr
Look for the model that the top of the cylinder mounts to the tailgate striker post versus the one that has a plate that is mounted under the striker that has a lower mounting stud. The ones which mount to the striker seem to be the larger, better cylinder.
Old Apr 26, 2011 | 01:07 PM
  #139
robroy90's Avatar
robroy90
I just got an email from Jeff @ DeeZee. He asked for my full address and told me that when they got it sorted out, they would send me a new kit. I won't post his info here, but PM me if you want his email address.
Old Apr 26, 2011 | 01:27 PM
  #140
frt2599's Avatar
frt2599
robroy.. It's not showing an option to PM you... It is for everyone else. Do you have this feature disableed?
Old Apr 26, 2011 | 01:45 PM
  #141
PITS's Avatar
PITS
I got the same e-mail from him...and my PMs work if you are interested.
Old Apr 26, 2011 | 02:33 PM
  #142
lyork's Avatar
lyork
I ordered mine from Amazon 4/21--It showed up yesterday and it's the new style that mounts with the plate. Will be sending it back, have an order in with O'Rielly will see if the old style shows up from them.
Old Apr 26, 2011 | 03:07 PM
  #143
TexasA&M's Avatar
TexasA&M
lyork - what year truck do you have?
Old Apr 26, 2011 | 03:15 PM
  #144
lyork's Avatar
lyork
2011 F-350, SRW, LB, FX4 Lariat
Old Apr 26, 2011 | 03:23 PM
  #145
TexasA&M's Avatar
TexasA&M
Is there any reason why the model for the older trucks won't work on the newer ones?
Old Apr 26, 2011 | 03:26 PM
  #146
houstonmr's Avatar
houstonmr
They fit with a little modification. I used the Stabilus model designed for the 2006 Super Duty which I found at O'Rielly. The hole in the tailgate is in a slightly different place. I drilled another hole in the bottom mounting plate and was good to go.
Old Apr 26, 2011 | 03:28 PM
  #147
TexasA&M's Avatar
TexasA&M
I need to start scouting the local auto parts stores to see if I can get lucky. Too bad there are no O'Reillys near me.
Old Apr 26, 2011 | 05:39 PM
  #148
houstonmr's Avatar
houstonmr
They are also known as Schuck's, Checker and Kragen. It says there are stores in Texas: Store Locator | O'Reilly Auto Parts
Old Apr 26, 2011 | 05:56 PM
  #149
TexasA&M's Avatar
TexasA&M
We've got them around.... just none on my way to anywhere!
Old Apr 26, 2011 | 06:14 PM
  #150
houstonmr's Avatar
houstonmr
You may be able to get the older one online through them.
