- AC sytem replacement question?
- Radiator Hose Fabric Material
- Noisy York...correct pressures??
- a/c hot;max cold
- quick question about ac
- I hear WATER?? 2003 F-150 ...
- blower only works on high
- WAY too much oil in converted system???
- Vacuum Check Valve
- heater core
- LOW Pressure A/C spot in a 1993 Explorer.. Where??
- no thermostat???????
- Blower resistor
- A/C problem, opinions needed.
- flushing radiator ??'s
- Broken vents
- Ford "black death"
- Flushing A/C system
- help finding vaccum leak
- New Operating Pressures for r134a??
- 1 row vs. 2 row radiator
- non ford ac ????'s
- Cant get system to charge
- exact location of freon refill "tit"
- No temp control w/A/C switch on MAX
- Too Cool?
- '94 E150 coolant leak from valve behind AC blower/evap assy
- A/C fixed.....kinda
- ac blow off valve
- Fan clutch replacement Q's
