- R12 Replacements?
- Reconnecting a removed compressor
- charging valve mounted on A/C compressor
- Excursion evaporator drain tube
- cab odors
- Colder A/C ???????
- Weak AC
- new freon in old A/C units??
- A/C Identification
- Attention HomerWinzlow
- Need AC help.
- Dash AC quits on acceleration
- R-12 Freon Replacement Options
- AC compressor comes on in all but one setting?
- max A/C problem
- 91 Ranger, Where Are The Common Leaks, Does Sealer Work?
- Gold Coolant--What's the advantage?
- 2003 F250 A/C Problem
- compressor shaft seal replacement
- I get 100% cold or hot air only
- DOH! I don't think it is the thermostat....flex fan question....
- A/C conversion TOO cold?!
- A/C drain
- 96 E150 Rear Air
- Thermostat or No Thermostat???
- a/c went out, no juice at plug
- F250 running hot and starter frying
- Coolant additive
- A/C performance
- A/C, Heater blower problem
