Cant get system to charge
Old Jul 29, 2004 | 04:30 PM
ststock23's Avatar
ststock23
I'm having a problem with my 89 Bronco. It has been previously converted from r12. I'm trying to charge the system. The compressor cycles every 5 seconds but it wont take in any refrigerant. When I try to jump the connector I blow a fuse. I let it run for about a 1/2 hour with the bottle connected to the low pressure side thinking it may take in enough during the time the compressor was cycling. No such luck. Any advise?
Old Jul 29, 2004 | 04:50 PM
Pikachu's Avatar
Pikachu
Maybe the charging coupler isn't depressing the schrader valve in the fitting? Are you sure the can is punctured?
Old Jul 29, 2004 | 05:07 PM
ststock23's Avatar
ststock23
Yes, can is punctured. Am I wrong, or will it not charge if the compressor is not cycling? It has to suck in the refrigerant right?
Old Jul 29, 2004 | 06:54 PM
Pikachu's Avatar
Pikachu
No, it doesn't really suck the refirgerant in. The refrigerant in the can is at a higher pressure than the low side of the system. Are you trying to top-off the system? What symptoms are you experiencing?
Old Jul 30, 2004 | 07:24 AM
ststock23's Avatar
ststock23
The a/c blows hot. The condensor recycles every 5 seconds for about 2-3 seconds. I tried to jump the switch but blow a fuse every time I try.
Old Jul 30, 2004 | 08:54 AM
macman85602's Avatar
macman85602
Was there refirgerant in the system when you started? If the system was empty you will need to deep evacuate the system first.
Old Jul 30, 2004 | 11:10 AM
Pikachu's Avatar
Pikachu
Yeah, what he said. That was my next question..... If the system was discharged, it will need to be evacuated before charging. Air, dessicant, and refrigerant aren't a very good mix. I have no idea why it would blow fuses by jumpering out a pressure switch, though.
