a/c hot;max cold
Old Aug 3, 2004 | 08:54 PM
rocky389's Avatar
rocky389
Angry a/c hot;max cold
97 Ford Explorer blows cold air on Max and hot air on a/c. Please help
Old Aug 3, 2004 | 09:17 PM
Pikachu's Avatar
Pikachu
[DISCLAIMER]I'm not certain about this, so it is just a theory for you to investigate further[/DISCLAIMER].....
Its possible that vehicle has a valve to shut off coolant flow to the heater core when Max is selected. If that is indeed the case, its entirely possible the blend door is allowing airflow across the heater core all the time, but the core is cool when max is selected. You might be able to test this theory by switching to normal a/c with the vehicle at operating temperature. When the air is good and hot, switch back to max. If it takes a minute or two for the air to cool off, the theory stands. If it cools immediately, back to the drawing board.
92will
Oct 5, 2016 06:25 AM
Tedster9
1983 - 2012 Ranger & B-Series
Jul 18, 2016 09:42 AM
AggieOutlaw
May 19, 2015 02:26 PM
timlikes2play2000
1997 - 2003 F150
21
Nov 6, 2007 08:06 PM
Supercab
Aug 23, 2003 09:58 AM
