PDA
View Full Version : Cooling, Heating, Ventilation & A/C
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 [174] 175 176 177 178 179 180 181 182 183 184
  1. Not getting cool with fresh charge... ??? Any ideas?
  2. 1970 a/c brackets
  3. blower stopped working
  4. AC clutch repair
  5. Vacuum lines
  6. '69 Heater Core
  7. High temp w/ AC on
  8. a\c pressure?
  9. Refrigerant Capacity
  10. 16 and 1/2 Qts Cooling System?
  11. 70' Sport Custom w/Factory Air
  12. someone have experience in air conditioning
  13. dual fans
  14. radiator dimensions
  15. F250 SD a/c refill orfice?
  16. air box
  17. a/c fan
  18. Weak air from A/C vents
  19. Under Dash Unit
  20. needs lots of advice! 78 crewcab air
  21. A/C is a must in a black Bronco!
  22. A/C clutch (?) not engaging
  23. converting R12 - 134 a problems
  24. 79 f-100 - Where to get A/C Clutch Dampener????
  25. Deluxe hi-lo blower motor current draw
  26. Replacing Blower Motor
  27. Proper charge for R134A
  28. Window Motor Replacement on 1990 F150 - HELP
  29. 79 f150 ac conversion
  30. 73 crewcab needs more cooling
