- AC switching over problems
- 1993 F150 4x4 thermostat probs.
- 95 explorer heater prob
- Heat and A/C control switch in dashbroad for 1991 Aerostar
- AC Compressor Clutch R&R
- a/c transplant
- radiator resevoir coolant is dark
- Oil Cooler Leaking
- cold running vehicles
- ac for a 77
- Who says a flush is simple?
- Fan Sputter
- ac air compressor
- Which Type of Anti-Freeze?
- Thanks
- heater blower only has output on high speed...
- Can't believe this worked!
- blowing hot air in a/c position
- Hotter thermostat fixed all kinds of problems?
- heater core
- no heat &...
- 84 f150 want to add A/C
- air pump/heater hose connections
- rear floor heat in Expy
- sending unit resistance
- Hot Rod Air A/C unit: stuck on "vent"
- hole in radiator
- Window fogging problem, HELP!
- Temp Gauge
- Aluminum corrosion repair
