flushing radiator ??'s
Old Jul 31, 2004 | 04:03 PM
nasa-hvac's Avatar
nasa-hvac
can someone give me the correct procedure for flushing the radiator and refilling it. I have a 98 f150 4x4 with the 4.6(?). thanks
Old Aug 1, 2004 | 10:00 AM
fishmanndotcom's Avatar
fishmanndotcom
go to aurtozone and buy the $8 kit. all the instructions are there. basically all you do is add an adapter to your heater hose that allows to hook up a hose to it. then you open the drain **** on the radiator and crank the motor. hook up a hose to the adapter on the heater hose and crank your motor. turn on the water hose and let it run for a few minutes and let it wash all the crap out! a lot of times it is better to get a special chemical that you pour in over night and it is like Drain-O in which it starts to clean your cooling system and breaks down a lot of gunk, rust, oil, particle buildups, etc. then fluxh your system out.
the best way to fill a radiator is to pour in an entire gallon of anti freeze in then pour an entire gallon of water. then with a second full gallon of antifreeze, split it b/t the 2 bottles. when ou have them very close to them same fill the bottles up the rest of the way with water and you now have another 2 gallons of pre-mixed antifreeze that is easy enought to haul alround and you have to pay the extra $5 at the store for the pre-mixed stuff!
-cutts-
amaezing
1997 - 2003 F150
Aug 7, 2016 01:20 PM
wahlturfcare
Jun 8, 2016 04:51 PM
2001gocougs
Modular V8 (4.6L, 5.4L)
Jan 28, 2016 02:59 PM
davisenvy
Aug 17, 2007 07:17 PM
matttt74
Jun 10, 2004 08:15 AM
