- how much horsepower this combo is good for
- Engine Break-in
- Duraspark Distributor
- 79 351m gasket set & valley pan
- Does anybody have good 400 engine recipe?
- 400 / 351m tranny
- Anyone moving big loads with a 400
- 351m manifold bolt removal
- Exhuast leak
- More power with moslty stock 351M
- 351 a 400? WHat is the highest cr piston 4 a 400?
- 351 cleveland hp?
- 351C oil drain holes??
- Whats the diff
- 351M Firing Order
- dyno This!!!!.... thanks
- Problem Starting after motor heats up.
- tell the dif between 400 351m ?
- How much total advance does the 400 like?
- 1.7 vs 1.73 comp cam rockers
- Hot off the dyno!
- valve cover number
- Hyd. Lifters - 351m
- msd 8477 problem?
- need some serious wiring help
- 300 vs 400
- 450whp 351M/400 in a 94/95 V6 Stang??
- Weiand water pump question
- engine wooes..........
- 351c Toploader bell housing on a 302??
