400 / 351m tranny
Old Oct 27, 2005 | 12:24 PM
forcury's Avatar
forcury
Question 400 / 351m tranny
Here's my dilema .....I have a '51 merc that I am trying to shoehorn a 400 from a '75 LTD into. All is well , as I am now putting on some Aussie heads, and 4 bbl intake , etc. My problem is trying to find a 4 speed to bolt up. I have a C-6 with 26k on it , but really want a standard "baddly" . I realize there is no car with a manual tranny that came with a 351m or 400 , but know there were many 2 & 4wd ford trucks that did. Here are my questions. I can use a bell housing from a 351m/400/429/460 ..........but must have the flywheel/clutch from a 351m/400 ?? Are the two flywheels the same on the 351m & 400? I believe I read there are two different clutch sizes, with the 400 being larger?
So , what I'm asking is : can I bolt up any bellhousing/flywheel/clutch from a 351m OR a 400 , to my 400??
Skip
Old Oct 27, 2005 | 04:20 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 28, 2005 | 10:21 PM
witdog2020's Avatar
witdog2020
Clutch
I made this switch your talking about, I went from a C6 to T18, the flywheel I used would accept either clutch,(flywheel same dia. on 351or 400) it was drilled for 10" or 11" clutch, and I used the 11" in the 351M. It wouldn't hurt to get a second opinion on this forum, This is the only time I've did this, so I'm not sure if all the flywheels have this option.
