Exhuast leak
Old Oct 26, 2005 | 06:43 PM
Chris_ce's Avatar
Chris_ce
Exhuast leak
I have a exhuast leak on a 351m. It is in the front of the head about a 5/8inch hole. I know that some engines had a pipe running to there, but what can I use to plug this up?
Old Oct 27, 2005 | 09:06 AM
Bill_Beyer's Avatar
Bill_Beyer
If you're talking about the A.I.R. passage that runs the length of the heads then it's plugged with an interference type plug (looks like a small freeze plug) from the factory. On most engines it has a threaded fitting on 1 end that is used for an accessory mounting bracket. Since the heads are interchangeable L to R most heads have a plug in 1 end and the threaded fitting on the other.
Old Oct 27, 2005 | 11:21 AM
Chris_ce's Avatar
Chris_ce
Are both ends threaded to accept a bolt ?
Old Oct 27, 2005 | 11:38 AM
Bill_Beyer's Avatar
Bill_Beyer
The threaded fitting is actually a threaded insert. The hole itself has no threads in it. You could drill & tap it for a small pipe plug if you felt so inclined or simply go to the local partshaus and find the correct size plug.
