- "Prefect" example of a sixth-gen?
- Truck back from paint shop
- 79 box repair
- To shim or not to shim, that is the question
- Air Conditioning Project 460 1977 F350
- Wirijg harness swap
- doors / side mirror mount
- Suggestions to get rotten core support bolt out without heat
- Front end shaking F250
- Where is the diagnostic location on a 97 U-Haul gas F-350?
- Remove Front Driveline or no?
- Difference in cab floor of 73-79 to 80-96 question
- Ready to spend some money again - Radiator / Digital Dash
- patch panels
- Gear oil
- Carb gasket installation
- Magnaflow or Flowmaster
- Radius bushing technique
- 1973 F100 Heater Core w/AC issues
- 351 help
- Which clutch fork do I need?
- intermittent dead key, weird issue on 351m
- Noise
- c6 shifter and kick down linkage
- Cup Holders for '75 Ford
- Starting a 73 F100 build.
- Rear Tank,Rubber fuel filler hose
- C6 Identification help
- Exhaust
- compression issues?
