- Vibration in steering wheel when parking
- where can I find the fuel filter on my 2002 ford explorer
- P0403 Exhaust Gas Recirculation Circuit Malfunction
- 1998 Explorer--need help baring
- 2003 Explorer AWD vs. 4X4
- 98 exp spt door lock
- Front Rotor on 97' Explorer
- 98 awd explorer 68,000 miles
- Keyless Entry Combination Code
- need help for my explorer's 4wd
- Damaged Ignition Cylinder 94 Explorer
- fuel milage difference-- 5.0 vs 4.0 sohc?
- Seat belt pretension noise???
- recent buy explorer 96
- Mountianeer Handling
- Sport Trac Computer
- 2001 vs. 2002 Ford Explorer
- no luck with blend door...how do i remove dash
- Intake coolant 4.0 ohv
- check engine DTC PO455
- 4 weel drive 4x4 problem
- OD Relay on 97 X
- SUBWOOFER Question
- 2003-2003 Explorer 4 doors bolt pattern
- Explorer 99' mistery battery drain
- noise from under the hood
- Rear Door Latch, removal help
- 92 Explorer No Start
- 99' AWD V-8 Overdrive Problem
- keypad code
