keypad code
Old Jul 12, 2003 | 06:54 AM
qb12xe's Avatar
qb12xe
Unhappy keypad code
small times
Hello,
I have a problem. I bought a 2002 ford explorer used. The keypad did not come with the code. Some say that there is a sticker but I am not able to find that. Please help.
Old Jul 12, 2003 | 10:11 AM
1956MarkII's Avatar
1956MarkII
keypad code
Ford no longer puts a sticker in the vehicle with the code. If you know which dealer sold the vehicle new, you should contact them. They MAY have a record of it; not every dealer logs this information, though. Your only other option is to have the dealer hook your Explorer up to their computer and pull the code from the vehicle's memory. The cost for this service is anywhere from $0-$60, depending on the policy of the service department. Once you get the code, put it on a sticker and attach it to the inside of your glove box.
Old Jul 12, 2003 | 10:49 AM
qb12xe's Avatar
qb12xe
keypad code
thanks for the help i will try to contact the dealer!
Thanks!
Old Jul 13, 2003 | 07:03 AM
75f100's Avatar
75f100
keypad code
i was told by an ex-ford employe that in the rear of the vech. there is a little cubie hole and somewhere on/in there is the code, but i haven't found it yet. and the dealership is gonna getta for bout $50 to hook it up to the computer. i'm having the same problem. good luck
Old Jul 13, 2003 | 07:20 PM
zoti's Avatar
zoti
keypad code
In the manual of my '98 it says the code is on the computer module (I have no idea where that computer is) and on a little card that came with the documents. I have the card.
Old Jul 13, 2003 | 07:31 PM
75f100's Avatar
75f100
keypad code
when you buy used, they arn't always still there.
Old Jul 14, 2003 | 12:09 AM
zoti's Avatar
zoti
keypad code
I know that but it's always worth taking a close look through the papers you get with your car just in case.
Old Jul 14, 2003 | 12:14 AM
Ponyracer's Avatar
Ponyracer
keypad code
Hey you guys are on the right track.
The code is behind the left rear access panel. open the panel and use a flashlight to look back inside at the module. There will be a sticker on it the will be hard to read because of the angle but that is where the code hides. At the dealership I used to work at we did this for free. I don't see how a dealership would charge for something so simple, unless they are hard up for cash and not customers!
Old Jul 14, 2003 | 01:34 AM
zoti's Avatar
zoti
keypad code
I checked. it's there alright.
Old Jul 14, 2003 | 05:09 AM
75f100's Avatar
75f100
keypad code
i'm sorry i must be stupid, could you explain which is access panel? thanks guys, this is a HUGE help.
Old Jul 14, 2003 | 11:37 AM
zoti's Avatar
zoti
keypad code
I don't know when was it that ford stopped putting the code in the pannel. This applies to my '98.
The panel is where your jack is sitting. It's in the back of the truck on the left. When you remove it you'll see the jack sitting towards the back of the truck. Right at the front of that panel you'll see a white box (I guess it's the computer). On it there is a sticker which has the code printed on it. It's a little hard to see because of the angel.
Old Jul 15, 2003 | 02:09 PM
qb12xe's Avatar
qb12xe
keypad code
well i have a 2002 and i heard that this sticker was stopped when the 2002 model was redisigned??. im confused. thanks for the help.
Old Jul 15, 2003 | 04:08 PM
rclarke's Avatar
rclarke
keypad code
Any Ford dealer can retrieve the keyless entry code in a minute or two. A quick hookup to an NGS or WDS (Ford test equipment) can retrieve the code.
Old Jul 15, 2003 | 08:55 PM
75f100's Avatar
75f100
keypad code
this quick hook-up cost $50 from my local ford dealer
Old Nov 5, 2003 | 04:04 AM
neuera's Avatar
neuera
hey guys. have you guys had problems with your keypad? I was trying to see if the keypad works. for some reason if the alarm is on, if i press the keypad it will sound off the alarm. but as soon as you press the unlock button on the keyless entry remote it will stop (of course) and if you lock it again and try using the keypad entry.. it will work without setting off the alarm. any suggestions on how to enter the numbers without setting off the alarm?
