- Will V8 fit in early 90s Explorer?
- M5R1 manual and rebuild question
- Bent spindle?
- Need some help locating a part for my 10 explorer!
- 98 ford headlight issues
- 2003 Explorer heater controls
- '04 Aviator tailgate plastic cracked
- 2002 / 4wheel drive: how to test CM and transfer motor
- 98 Ford Explorer banging noise from front end
- Check Engine Light
- FYI: A "GEM" of info...
- Freeze Frame stats
- M5ODR1 Transmission Manual?
- 2002 Explorer no heat?
- ADD AN AMP
- Lugnuts on my '04 EB...
- Replacing rivits while dueing radius bushings
- overhead console display ?
- snow chains/cables
- Front left ratcheting sound.
- New Life For An Old Explorer
- How to: Disable "Oil Change" warning on '04
- 2010 Adrenalin with stiff brake pedal
- P1131 & P1151 DTC's
- Tranny Issues 98 ford explorer sport 4x4
- '97 Explorer makes clunking sound going into 4-wheel drive.
- Help! Ford Sport trac fuel reset problem
- trying to find the od sensor
- 2003 4.0 timing
- '98 Explorer - repairs needed, invest or say goodbuy
